![]() | Home > Maintenance & Modifications > Best Tyre Size for Overland Defender |
drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193 ![]() ![]() ![]() |
Hi Guys,
Looking at what tyres to fit to our Defender 130 overland expedition vehicle and wondered if anyone had any suggestions. We are leaning towards BF Goodrich All Terrains, probably on wolf wheels. Does anyone have ideas on the best size tyres for the job? Or any other tyre options for that matter? Perhaps there is something we have not considered. Many thanks Steve |
Probably most sensible to use a tyre size that is common in the countries you are travelling through .... 750/16 ?
Perhaps tubed tyres would also be a good idea so that punctures can be fixed 'in the field' Wolf wheels are nice and strong and being steel can be hammered back into shape |
Good points as always
![]() BFG don't do tubed tyres do they? Does anyone have any recommendations on a brand? |
Sam Watson of LRO fame spends a lot of his time overlanding and is now based in Egypt, might be worth contacting him for his advice / experiences ?
I've PM'd his email address to you |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Where are you planning to overland?
Most countries now have a relativly good selection of tires and sizes- about 5-10 years ago as mentioned by Matt the 750/16 would have been the safest bet- but in UK now if you ask a place for a 235/85/16 or a 750/16 they will more than likely have the 235 over the 750s. Tubeless tires are just as repairable as tubed tires- just get a quick repair kit like this: ![]() http://www.amazon.co.uk/Silverline-Tyre-Re...B001QUN9UQ and then find a place that does the mushrooms, or even get a mushroom kit for when you have a maint day. If overlanding in proper wilderness I would also suggest 2 spares rather than one. With tire choice, I would be tempted to go for the mud terrains- they tend to have a slightly stronger sidewalls. Glyn ![]() ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Michelin 7.50 x 16 radial
http://www.ajstyres.co.uk/tyres/michelin/michelin_offroad.htm General SAG radial 7.50 x 16 radial http://www.ajstyres.co.uk/tyres/general/su...radial.htm Both tubed. Have had the SAG radials on a 110 200 tdi for years. The Michelin XZL 7.50 x 16 radial is highly regarded for overland use by Tom Sheppard. Land Rover still offer the Michelin XZL 7.50 x 16 as an option. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Have seen the XZL before. Isnt that the tyre used by British Army?
Yes they have used it.
Can photocopy the relevant pages on tyres, from Tom Shepperd's Vehicle Dependent Expedition Guide and PM them to you if you want but Sheppard comes down heavily in favour of the Michelin XZL. Probably a bigger selection of tyres suitable for the job out there since the book was written in 1999.Great read, full of info. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
May have to find a copy. If you could message me that page would be great! Thanks
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
does this help:
[img]https://www.defender2.net/gallery/albums/userpics/11014/Vehicle%20Dependent%20Expeditions.pdf[/img] not sure why but cant load the pdf. please look in my gallery BM52 |
Have just looked at our two editions of Tom Sheppards VDEG
I can not see anywhere that Tom recommends a 7.50 tyre To paraphrase Tyres - what to choose Mixed Going BFG A/T Mainly mud Michelin O/R XZL or BFG M/T Mainly sand Michelin XS Back to tyre size 7.50/16 has tread width of 190mm and overall diameter 31" 255/85/16 has tread width of 255mm and overall diameter 33" The 255/85 will give an extra 1" clearance under the diff. The 255 is about 1/3 wider then the 7.5 plus a longer foot print will give about a 50% bigger footprint then the 7.5. This translates to a lower pressure on the ground. If the ground is softer then the bigger the footprint the less likely for the tyres to sink into the ground. We use 255/85/16 BFG M/T on our 110's and have done trips of up to 25,000 miles as a solo vehicle. Our reasons being good hard wearing tyre which can cope with most terrains. The 255/85 gives us good ground clearance, good on rutted tracks and a decent footprint, reasonably good on sand apart from dry fine sand. OK has a greater stopping distance on wet tarmac then a A/T. So in wet weather just ease up on the accelerator! Brendan |
"Forget fancy sidewall lettering. If bewildered by multiplicity of makes (or even if you aren't) go for Michelin. If still bewildered, go for the XZL (XS if mainly desert)"
"Mixed going. Tarmac, tracks, mud, desert, churned sand -Michelin XZL. Almost putting the lie to the saying -there is no such thing as a good compromise-,the XZL confronts typical mixed-going expedition conditions with extraordinary efficacy. Capable of an exceptionally low 0.6 bar emergency soft inflation (12 mph max) it has circumferential sidewall ribs to protect against sidewall damage at these vulnerable pressures." Page 4.2-25 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
From edition 2.1 2nd and edition 2.2 Tyres have changed an awlful lot and peoples opinion! So Tom Sheppard NOW (well 2011) recommends BFG tyres except for soft sand. My PERSONAL choice based on my personal experience is BFG M/T 255/85/16. Road noise from them? No problem I am driving a Defender and there is plenty of wind/engine noise etc not for me to be concerned by tyre noise. Stopping distance in the wet? Test have shown that the BFG M/T has a 10% greater stopping distance in the wet compared to A/T. (This test was carried out by LROi many years ago, how the new KM2 compares to current A/T I do not know) One solution to that is to ease off the accelerator in the wet. Brendan |
Always willing to learn. Like I said there are no doubt more tyres to choose from today. Hard to beat first hand experience.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
