![]() | Home > Maintenance & Modifications > Rear Work Lights |
Believe this is what you mean: http://www.farcorners.co.uk/products-page/...unt-point/ Seems a good idea, but it may be a bit too low to shine down onto certain things, if you get what I mean. An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
thats it gum - i quite agree about the amount of light spread in relation to the mounting height but i'm sure it will fulfill some folks needs.
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 ![]() ![]() ![]() |
If you want to keep a low profile, check these flood lights I fitted from Rigid Industries.
![]() Click image to enlarge The rest of the photo's are here: https://www.defender2.net/gallery/thumbnails.php?album=958 Cheers Peter |
hi peter,
those lights look excellent ![]() |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Good summary Brendan
![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20762 ![]() ![]() |
Peter - I assume then with those as the light body is actually true to the Defender body that the LED's are slightly angled down? WeWillWin🇬🇧🇺🇸
that thought crossed my mind steve; but if you have a look at the rest of peters pictures linked on his post you can see that the spread of light is extremely good for close work jobs. (ie not a spotlight for bunny shooting tasks). i suppose you could always shim or pack out the upper section of the fitting if you wanted more downward light? |
Nope they have to be mounted on a flat surface. Yes you could tilt them with a split shim, or do what I do
And act as the deflector ! They are diffused. So light is spread out. They have others on their range. But thought these look smart and only came out 3 months ago. Speak to Mikes2005 on rigid industries topic on this mod category. About cost. BTW they are ip68 not ip67 that let water or condensation in. You do have to cut hole in roof though, but as have county interior, the heat sink is well hidden. Look well smart and discreet. Low 2.5 amp draw. Have had 110 watt work lamp in past but with a metre on battery can see it draining very quickly. You can just leave these on - off road of course. Not cheap to buy, then again not rubbish !! As rugged as vehicle they are fitted to. Easily see across a 2 acre field BTW. |
