![]() | Home > Puma (Tdci) > Water Leak |
It took two fixes to resolve this on my 110.
Sealing the windscreen (DIY job) and the dealer replacing the foam seal between the bulkhead and windscreen frame. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Lots of history on these probs (search should help)
In my case top of window rubber let water run around inside and down to behind dash Also foam seal under frame leaked Others have leaky door seals Try duck tape and a hose pipe to find out which :thumbs up: Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Mine leaked through the grommets where the windscreen wiper on LHD models are attached. Leaked into passenger footwell.
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I have just found and printed out water ingress manual from Land Rover
![]() Perhaps I should do a copy for the dealer. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
I'm serious - Duck tape plus hose - process of elimination
![]() But shout it at them in German because life is also terrifying and confusing... |
Question about the foam seals. Mine seem to be doing their job, so I must have one of those Defenders that were not produced on a monday morning or friday afternoon...
A couple of times per year I will use a silicon spray on the door seals and window/sunroof rubbers to keep them supple and in good shape. What about all the foam seals, what to use to keep them in good shape and keep doing their job for a long time? Same silicon spray? Different products? Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
I'll beat K9F to this - Sikaflex it's brilliant sealant and never goes off (use gloves otherwise it will never come off your hands), I know for sure they do it in black and white. it's a marine sealant, used by caravan owners too
alternative is to run tape (clear or whatever) along the seal under the windscreen. |
LR dealer has just resealed and resprayed the roof ("forgot" the foam seal) so I don't want to loosen the roof/frame) to change it.
For now I've just got a bead of butyl tape along. Been fine for six months. I'll probably use window sealant (also butyl) eventually as it stays a bit soft. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
