Home > Puma (Tdci) > Doors
Caterham
Doors
Big Cry
someone tell me its me ...... and I'll walk off and shoot myself !
mines in for the following at the moment;
new seat frames as the pains all flaking off
mud flap brakets - all rusted
new front bumper - paint all flaking off
front grille - rusting
head light retaining rings
rust on bulk head (inside and out)
dodgy central locking
drivers side carpet
drivers door (bowed) and therefore rubber window strip doesn't fit.......and thats the problem.
I went to see how they were getting on with the work the other day a the guy doing the work said 'this door is much better - doesn't have all the ripples in it like the others'
not sure if I should be pleased but I feel a little p!ssed off that the others are all gonna look wrong and the new one will stand out like a sore thumb Big Cry
-3 more new doors - what do you think?.......and before you say anything I was joking about the shooting !
Post #171491 28th Sep 2012 8:07am
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
How old is your truck? 90 XS
Volvo V70
Post #171495 28th Sep 2012 8:13am
K9F
2011 if you hovver over the Avatar.....Doh!!!! Laughing
Yours will be 2007 then.... Whistle
Common as muck! Another 18 months and you'll be in exactly the same situation. I have purchased (not seat frames) all replacement superior quality items to preserve and save the inconvenience and frustration of these well-documented and inferior quality items and the trips to the dealers to get them swapped out. 'Warts 'n' all!!!!!'
As for the door if you gently knee it below the handle it'll soon match all the others..... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #171496 28th Sep 2012 8:14am
Caterham
doh !
hadn't thought about trying to make the new one look like the others.....was thinking the other way round - Big Cry
I'm expecting the bumper and brakets to need replacing (where's entreq's phone number)
but wasn't expecting the seat frames to shed their paint !
Post #171500 28th Sep 2012 8:22am
K9F
Extract from the thread link below.....most of the items you mentioned are contained within....
K9F wrote:
As mine was reaching the three-year point I took Fekete's advice and banged it in a month early for an MOT so any problems could be sorted under warranty if possible. No problems it sailed through.
Went over the bodywork with a fine toothcomb and as I type this the vehicle went in for a 'weeks worth' of paintwork issues that surprisingly were accepted without quibble to be done under warranty.
The 90 has two vertical welds below the windows on the side (the 110 doesn't posess these welds) one of which wasn't formed correctly and subsequently the paint cracked and there was evidence of rust bubbling. Reformation of the weld!
On the nearside corner of the windscreen between the rubber seal and the 'non functional' hinge blocks there was also evidence of paint lifting and a small track of bubbling. Windscreen out job!!!
On the rear there are two small shaped panels that are riveted to the bodywork either side of the vehicle above numberplate height. There was very minor corrosion evidence due to the original paintwork not adhering to the sharp edges. Smooth off the sharp edges slightly and respray.
With everything else that has caused me grief with regards to poor paint finish having been either swapped out for superior products or reworked to prevent reoccurence such as hinge blocks, headlight retaining rings, front bumper, sidesteps, window latches I am hoping now to have a period without rust cultivation, paint flaking and the depressive feeling when it is discovered for some time to come.
Westover Motors Christchurch have had an attitude transplant compared to historic experiences as mentioned in a previous thread! Thumbs up to them from me!!
Fingers and just about everything else crossed. Thumbs Up
Linky fingy:
http://www.defender2.net/forum/topic6310.html?highlight=flaking If you go through life with your head in the sand....all people will see is an ar5e!!
Post #171501 28th Sep 2012 8:25am
yorky
Chill - Maybe when I've been a member as long as you I will realise such things! Wink
 90 XS
Volvo V70
Post #171531 28th Sep 2012 9:44am
Caterham
Very Happy
Post #171533 28th Sep 2012 10:02am
