![]() | Home > Puma (Tdci) > Heater |
Anvil Member Since: 16 Jan 2009 Location: Milan Posts: 21 ![]() ![]() ![]() |
Hi vogue
Yes this is a known (not well ![]() There is a bullettin that explains how to fix it - SSM39653 I can't find it in the GTR's english section (obviously ![]() Some friends here in italy faced this problem but I don't know if someone tried to fix it on its own because a sort of a seal it's required. |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 ![]() ![]() |
It's a problem for RH models too.
I took mine back to the dealer for this reason (my Mrs gets cold quicker than me and as hers is the cold side, it was causing problems!) They measured several other vehicles and they all read 2C colder on the LH side than the RH side - no fix offered. |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
I suffer constant complaints from the passengers front and rear. ![]() I have a theory based on the right hand drive version: The warm air from the engine bay (and it gets quite hot) finds its way into the drivers side via the hand brake hole. Who would ever have thought that this would be an issue in a Defender. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
Here is it
http://rapidshare.com/files/210802251/Heater_fix.pdf.html link updated Last edited by Anvil on 18th Mar 2009 8:14pm. Edited 1 time in total |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 112 ![]() ![]() ![]() |
Many thanks for the reply.
![]() ![]() I can't find the GTR section but no problem. I check it at the dealer. |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
The file attached in the link above is not available, can someone send to me a copy?
Thanks!! Matteo Defender 110 Td4 SE MY 09 |
The uploaded file seems to be unavailable
here is a new one http://rapidshare.com/files/297726421/Heater_fix.pdf.html Cheers |
WinBoot Member Since: 09 Jan 2010 Location: Ieper Posts: 28 ![]() ![]() |
Could anyone reupload this? Cant find it anywhere and my passengers are complaining heavily from cold
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 324 ![]() ![]() |
I think you will need to refer back to the original Puma Test Files. A realisation occurred in Tromso, I think, that there was a need to keep the driver warm in sub zero conditions, whereas a culled Reindeer or Moose (in Canada) left in the rear of the vehicle or even in the passenger area would suffer from heat on a long drive back to the lodge. So, this was inbuilt at the time, and very effective it is too!
My dealer done the job on my Defender in february 2009 and, now, it works great!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Hi Guyz
I've just re-submitted the pdf http://rapidshare.com/files/363668798/Heater_fix.pdf.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Added to the Defender2 gallery so it won't be deleted from elsewhere, and no annoying waiting: http://www.defender2.co.uk/gallery/albums/...er_fix.pdf
Great !
