Home > Puma (Tdci) > NAS reversing & rear fog light each side.
Page 1 of 3 123>
BigWheels
I see some Defenders have a NAS rear fog & reversing light each side. I asked about getting them fitted at my LR concession shop who said it could'nt be done because of wiring etc.
Surely this is wrong! Apart from the light units, what do I need to buy & do/have done to get the lights fitted? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #170572 24th Sep 2012 8:43pm
T1G UP
you'll just need to run supplies over the other side for both.
Post #170575 24th Sep 2012 8:47pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Re: NAS reversing & rear fog light each side.
Couldn't be done isn't something you often hear at any Land Rover specialist. It's not even that difficult. You just need to take a parallel feed from the nearside to the off side for the fog and vice versa for the reversing light.
Any auto electrician could sort this for you.
Post #170576 24th Sep 2012 8:47pm
Porny
Site Sponsor
Due to the same chassis loom being used for LHD and RHD for some applications... you might find the wiring is already there!
If not, just be careful about how much current draw you are putting on the standard wiring... or fit a pair of LED NAS fog and reverse lamps - which are not only brighter, but draw a lot less current.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #170665 25th Sep 2012 9:15am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
On my 51 reg TD5, the wiring/sockets for fog/reverse lights are on both sides. So it should be plug and play, subject to current draw...
Simon
Post #170668 25th Sep 2012 9:17am
farmer giles
lights like this always remind me of the old toyota supra
Post #170670 25th Sep 2012 9:24am
BigRuss
I like the idea, it should give you more light when reversing without the need to fit a flood light.
And it does make the vehicle look balanced Thumbs Up Russell
2011MY 110 XS USW Black
Post #170671 25th Sep 2012 9:29am
grafty99
I think side lights in the fog lights would look good. Increase rear visibility too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #170677 25th Sep 2012 9:45am
BigRuss
A set of indicators and stop/tail lights mounted high up in the back of the roof make you more visible Thumbs Up Russell
Post #170727 25th Sep 2012 11:59am
leeds
On one of our Defenders we did have high mounted indicators and brake lights at rear.
However just had a look at the regs about maximum height
Indicators
Quote:
(c) Vertical–
(i)Maximum height above the ground–
(A)Any vehicle not covered by sub-paragraph (B) or (C): 1500 mm or, if the structure of the vehicle makes this impracticable, 2300 mm.
Now are roof mounted indicators on a Defender 100% within the regs??
Brendan
Post #170745 25th Sep 2012 12:40pm
Brendan
Given this bit:
You could argue that they're legal on a SW that has glass in the rear quarters but not on a USW that has a flat panel. However, as they would be supplementary to the the OE ones, then it could also be argued that the regulations have already been satisfied. It would be different, of course, if they were the only rear lights.
In practice, there are lots of vehicles with these sorts of repeater lights higher up, from ambulances and recovery trucks to coaches and tank wagons, so I doubt that there's too much to worry about. Darren
Post #170752 25th Sep 2012 12:54pm
BigRuss
Not going to much into it, they are talking about fitting a single set, here were talking about fitting additional light that more than meets the legal requirement. Thumbs Up
What plod will pull you for having 2 sets rear of indicators like the disco 1's? Russell
Post #170760 25th Sep 2012 1:33pm
T1G UP
my 300 had the two sets...much better than just in the bumper.
Post #170787 25th Sep 2012 3:44pm
me@td5.org
Although I see the point of having 2 reversing lights I don't like cars with 2 fog lights.
The worst of which are Fiats which often have 2 close together which, when they are the only thing you can see through the fog, give the impression that the car is further away than it really is!
Post #170811 25th Sep 2012 5:29pm
BigWheels
How I want my 90's behind to look. Cool Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #170860 25th Sep 2012 8:31pm
Page 1 of 3 123>
