![]() | Home > Td5 > Odd problem - Shaking, prolly transmission? |
Welcome
![]() Number one (the howling) is quite common or so I am told. Mine is a 2001 TD5 with 57K on the clock and does the same thing. I have been told it is the release ??? (somebody will correct me if I have the wrong one !!) bearing and that it is nothing to worry about until clutch change time. Point two does sound like a DMF problem but somebody with far more knowledge will be along soon to give you the correct answer. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
MPN Member Since: 23 Sep 2012 Location: Tuusula Posts: 18 ![]() ![]() ![]() |
Thanks Bob!
I do have a gut feeling that I have a complete clutch ovarhaul ahead of me, but better check first. Having this done here with proper parts will be closer to a 2K€ job for sure. ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Usually on part clutch, the noise you tend to hear is the spigot bush, which is a self lubricating metal bush in the end of the crank which the gearbox input shaft fits in. Once this starts to get noisy, you need to renew it to stop the noise. Very cheap (£1.50ish) but is often not done at clutch time if not done by a specialist garage. You also run the risk of damage to the oil pressure loom and crank sensor if not done by someone who knows what they are doing when removing/refitting the gearbox.
Your other issue could be several things. It may be worth trying something. Going along at speed on a clear road, depress the clutch pedal and see if the vibration continues. See what happens as this will narrow down the problem. An AP or Valeo clutch kit, LUK dual mass flywheel unit + hardware and spigot with the labour at an independent is likely to be around £900 with the VAT. |
^Many thanks for that!
I'll give this a try. I'd say that in higher speeds this does not happen, but I'll check. In UK GBP900, in Finland easily EUR2000. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 ![]() ![]() ![]() |
There was a recall c. 2002/3 on TD5-engined vehicles concerning the spigot bush. This is an "oilite" bush which is supposedly lubricated for life, but my understanding is that a rogue batch slipped through without having been imprognated with oil. The result was a squeal from the bush when the clutch pedal was depressed and the engine was cold, or sometimes no squeal but great difficulty engaging 1st or reverse when stationary. My Disco had the bush changed for this reason.
OK. I tested flooring the clutch at higher speed. Nothing,
These shakes only appear when the car is slowing down (might begin at 30kph or so) and are strongest just before it comes to complete halt. As said, this happens only when the engine is hot. It feels a bit like the engine is about to stall. As soon as the car stops, this goes away. I would not be extremely surprised if this would be more engine/electrics related after all, but I still think it is the clutch/transmission dept.. This does not feel too bad, and surely is not severe...yet. I'm just wonderng what the hell is going on. Personally, I think my problem #1 is the release bearing(I think that's what it's called in English). Rather classic problem for Defenders of this age it seems. Somewhat inconvenient, but would not rush to fix it alone as it is apparently not harming the rest of the car. However, Blackwolf may well be right. Though I have no problems switching gears, ever. Thanks for your answers and opinions gents! |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 ![]() ![]() |
It could be a stiff propshaft UJ that is causing your judders. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
OK. What does "UJ" stand for?
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
Universal Joint 90 XS
Volvo V70 |
OK. Thanks a lot!
