Home > Maintenance & Modifications > LED head lights
Page 2 of 14 <123 ... 121314>
Norm4n
What about a cheaper alternative, the HID Xenon's???
Post #169794 21st Sep 2012 9:07pm
unless you have approved headlamp levelling and washing system HIDs are illegal for on-road use
basically you have 5 choices:
1. leave standard and don't go out in the dark
2. upgrade to crystals and more hi-tech lamps (I have PIAA extreme brilliance)
3. upgrade switch - add relays and put in whatever lamps you think you can get away with (100-200-300watt)
4. LED headlamps - I would recommend you actually see some LED headlights in the dark before purchasing ... they are amazing and you can "do things" to them to make them even brighter Whistle
and the final 5th .. really depends on how much you can use your full beam - buy a Rigid Industry 40" E-Series LED Bar - awesome
Post #169841 22nd Sep 2012 7:10am
Norm4n
Does a TDCI have approved levelling and washing😃?!!!
Do you need to spend £500+ for LED's?
Post #169847 22nd Sep 2012 7:31am
the LED headlights don't need SELF levelling or washing, unlike HIDs
headlight upgrades are not cheap !
Post #169858 22nd Sep 2012 7:56am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Is it me or are those led ones fugly? Rhubarb and custard let fly with their secret weapon.
Post #169864 22nd Sep 2012 8:15am
it's you Rolling with laughter
sorry could not resist
Post #169867 22nd Sep 2012 8:24am
Porny
Site Sponsor
Nope... They don't unfortunately.
Bpman,
You missed the most important factor... You need a 7" lens that is type approved for a HID bulb, rather than a standard halogen bulb.. which as far as I know doesn't exist.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #169870 22nd Sep 2012 8:44am
The LED cost to upgrade is little different to an OEM Xenon upgrade its that simple.
I was one of the early takers of the UK units and I can not praise the lamps or the customer Aftersales service that Tim and the mobile centre have offered. All of my exterior lamps are LEDs supplied by Tim.
You pays your money it's your choice Thumbs Up
Oh I'm not afraid to say as it is good or bad so had I spent what I did (they were way more then) and they were poo I would have said, do your homework first or simply as BP has said park you Defner up in these cold dark days Rolling with laughter Wink
Post #169874 22nd Sep 2012 8:53am
Norm4n
Who's TIM??? Embarassed
Post #169902 22nd Sep 2012 10:35am
Tim runs Mobile Centre, they are a sponsor on the forum
http://www.defender2.net/forum/mobile-centre-vf38.html
Post #169904 22nd Sep 2012 10:39am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
[quote="bpman"]4. LED headlamps - I would recommend you actually see some LED headlights in the dark before purchasing ... they are amazing and you can "do things" to them to make them even brighter Whistle[/quote]
I'm interested BP, what are these things?
Regards,
Mark
Post #169912 22nd Sep 2012 11:29am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Simple question to those who actually have LED Headlights
I was speaking to someone who has just fitted them and he said that on dipped beam their light output was amazing, but on main beam they were no better than standard bulbs and he recommended and uses aux driving lights to compliment the main beam output.
I am not knocking the lights - just want an honest answer - may need to see them working in the dark myself.
I have Tims LED 70mm lights all round and they are fantastic, and would love to complete the transition with Headlights but only if they are brighter than my upgraded 110W IPFs
Post #169922 22nd Sep 2012 12:37pm
pope10001
Hi Gavin,
I have just fitted them to my 90 out here in the UAE and i agree with your friend, the high beam isn't that much better than the low beam, but compared to the original high beam i think it is better. Saying that, i will probably compliment mine with some better aux lights as well. I have Lightforce 140's on at the moment wired in to come on with high beam and they struggle to make much difference to the LED high beam light. When i only had the standard Defender lights on the truck the Lightforce 140's were awesome. So i guess the LED's high beam isn't too bad. I think the problem is that the low beam is so good that the high beam seems to be poor in comparison to the low beam.
I will be bringing mine back to the UK to use on the Northern lights trip next year. If you want too, you are more than welcome to come down to Devon 4x4 to see them before you buy (if you can wait that long?) I honestly couldn't say whether or not they are better than your 110W IPF's, but maybe we could do a side by side comparison in January?
Regards,
Mark
Post #169926 22nd Sep 2012 1:25pm
boode
Thanks Mark
Side by side trial sounds like a plan - thanks
I thought you were taking your old Td5 90 to Norway not the puma ?
Gavin
Post #169928 22nd Sep 2012 1:41pm
"things" = wiring them up so that the dip and full are on at the same time ... Thumbs Up
Post #169929 22nd Sep 2012 1:57pm
