Home > Td5 > Diff question. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
Yes, they'll fit straight in.
you may be better off getting some HD axle shafts though (like V8 24spline, although the drive hub is bigger with those... a factory disc braked HD shaft isn't listed (if you run alloy wheels then the hub will be too big)) you could always get some from Ashcrofts. |
19th Oct 2009 9:05pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Is the 90 on 24 splines or is that the 110 Original Member Pie n Pea Club.
110 HCPU Tipper |
20th Oct 2009 8:09am |
All 90's from late 200Tdi 1992~3 with disc braked rear axles are 24 splined
20th Oct 2009 11:48am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Thanks guys,
I'll stay with the standard 24 spline shaft for a while. I'll have a look if they are the same as from the Camel as I only broke 2 in 7 years. I only paid about 35 pounds for each so I probably buy a spare set, so they don't break. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
20th Oct 2009 8:32pm |
