Home > Maintenance & Modifications > stainless bolts |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
+1 sounds a good idea , i brought some aerosol cavity wax which arrived today went mad every were and really did go in well CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
18th Sep 2012 6:55pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I'd be up for that, in fact I've been trying to get a price out of him for the past 2 weeks, business must be very good for him to ignore potential customers. |
18th Sep 2012 7:04pm |
is that just for doors id be after a full kit for a 90 CSK Automotive
18th Sep 2012 7:37pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
Just the doors.
I think the full exterior kit for the 110 was £100 |
18th Sep 2012 7:41pm |
wawaweewa for a 90 on there site its £80 inc vat with a bit of forum discount off of that i wouldnt mind having it CSK Automotive
18th Sep 2012 7:45pm |
Full 110 SW kit for me please
18th Sep 2012 7:51pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
Expensive yes but it's complete kits and also will last for a very long time indeed. No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
18th Sep 2012 7:54pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Where's Brendan when you need him It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
18th Sep 2012 9:04pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Don't kick me too hard lads. Life is very busy at the moment so it can be hard keeping up with all enquiries.
Have asked Barbara to put the stainless screw sets on the website, but she does have a day job as well. Please bear with her Nakatanenga Stainless screw sets, the screws have the same heads as the original screws on the Defender!. With these sets, all externally visible screws on the vehicle are high-quality, stainless steel V2A stainless steel screws. The side door and rear door hinge screws, and the screws on the body mount at the rear are made especially for Nakatanenga are now in the form of the original screws (Torx tool holder). Dependent on set, typically The screw sets are packaged clearly for each part of the vehicle in 10 bags: - Rear Door Hinge - body mount rear - grille - loading bar + reflectors - bonnet hinges - crossmember rear - Spare wheel - Eyebrows + fender covers - side door hinges - door sill inner + A-pillar + 2 buffer screws + a tube of anti-seize paste for the screws. VAST110 HT Stainless steel screw kit for Land Rover Defender 110 HT Approx 380 parts £85 VAST110SW Stainless steel screw kit for Land Rover Defender 110 SW / 110 CC / 130 CC Approx 430 parts £99 VAST90SW Stainless steel screw kit for Land Rover Defender 90 SW / HT 90/90 softtop Approx 380 parts £85 VAST2DR Stainless steel door hinge bolt kit for Land Rover Defender 110 HT/90 Complete screw set for 2 front doors and rear door, V2A stainless steel for Defender 110 HT/90, including Anti Seize Paste. £41 VAST4DR Stainless steel door hinge bolt kit for Land Rover Defender 110 SW/130CC Screws have identical heads as the original screws on the Defender! Complete screw set for 4 doors and tailgate, V2A stainless steel for Defender 110 SW/130CC, including Anti Seize Paste £59 Carriage etc. Brendan |
18th Sep 2012 9:09pm |
Sorry but any idea on 110 DC It's good to be back from the dark side
18th Sep 2012 9:19pm |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 |
Thanks Brendan,
Didn't mean to cause offence, however I will have a full set for a 90 from you Many thanks, Nobby _______________________________ Puma Defender 90 |
18th Sep 2012 9:20pm |
Might have missed it did you list it as 110CC It's good to be back from the dark side
18th Sep 2012 9:21pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I'm not so sure it's a good idea to introduce a third metal (copper) when you're trying to prevent galvanic corrosion. I think most of these recommended pastes, including the ones which Entreq and Nak supply with their kits are ceramic based and are designed to try an isolate the parts from each other. The corrosion occurs when water gets between the two different metals (steel or ali and the stainless screws) and forms an electrolyte, which accelerates the corrosion process. Pete |
18th Sep 2012 9:59pm |
ill go with there ones pete i want it rust free so hows about this group buy CSK Automotive
18th Sep 2012 10:50pm |
