Home > Puma (Tdci) > Blackbox faultmate |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I have the MSV-2 for my D3, I didn't buy the Td5 software yet as the Td5 is a very basic version no alarm, central locking, traction control, abs etc
So I wait till I really need it. So I cannot comment on the Defender software. I like the software for the D3 and that is still under development, but can do a lot what the Dealer can't do. The experience I have with the Blackbox is good. I had a waranty problem and that was solved good and quickly. But what really amazed me was support on the software side. I had problem switching on satnav on the move in my D3. It worked on other D3's but mine gave a problem. Within 2 days the problem was found and a special patch was written and put on the website for downloading and this solved my problem. Blackbox is a small company and gives you very personal service. Their helpline is a forum and I had first my doubts about that but I am now really convinced about that as you can read the problems others had and you can get help from others solving your problem and that doesn't have to be a MSV problem but also a diagnostic or something like that. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
18th Oct 2009 3:00pm |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 |
Hello Roel,
Thank you for your reply. I hope it's as good as i expect. I will tell you more for chrismas. If someone has more info. Thanks a lot |
18th Oct 2009 10:04pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
I conversely had really bad experiences with them for the Defender 2 - i admit it was new then - and lead to a return.
I cant decide if ill return to them, ive heard many different things, all boarder on the task the kit does is good and the other elements are bad. If it can do what its supposed to then i may go back - its still a stressed may Mike |
19th Oct 2009 12:07am |
Hi mse,
What was your bad experience with them, do you think that it's better for me to take the Hawkeye from bearmach? The full capacity faultmate, if it works as they wrote, seems to be wonderfull. What a problem Thanks for your reply |
19th Oct 2009 5:08pm |
The fualtmate - technology capability wise i think would be far superior to hawkeye, in terms of capabilties.
Where i had issue with it was it didnt work and most importantly (as they were to fix it) the customer service was shocking, beyond bad...i could have waited for a fix but the attitude was very much you only spent £500 you can wait, we only make £70 on each one. Mike |
19th Oct 2009 5:58pm |
OK,
What was your engine when you had problem with them? Do you think that i should take a faultmate? Thanks |
19th Oct 2009 6:50pm |
2.4tdci Mike
19th Oct 2009 7:08pm |
You don't use your faultmate on your puma, now?
19th Oct 2009 7:16pm |
I sent it back Mike
19th Oct 2009 7:46pm |
OK
Thanks for all I'll think about it. I'll surely bring a diagnostic tool from France in january, (maybe) the hawkeye or (surely) the faultmate. I hope I'll have more chance. Thanks at lot |
19th Oct 2009 8:40pm |
