Home > Technical > abs tc
shazzy90
abs tc
okay you might say not another thread on this,well my abs and tc lights have been on now for 2 years ,resetting the faults for the mot and 2-3 days later they would come back on,the strange thing is last night they went off by themselves,no i did not plug in to reset them,they just went off,they still light up when starting engine ,also i can now hear the abs block working when i approach a junction in second about 15mph all clear relese clutch to go and i hear the noise is this normal?
Post #167706 11th Sep 2012 7:08pm
K9F
Laughing Question must be asked having run with the lights intermittantly 'on' for the last two years are you really that bothered they've now gone 'out?'
In answer to your question the ABS block noise you hear when approaching a junction is not normal. I have TC and ABS and have sufferred issues myself. I know how frustrating it can be but had them sorted whilst the defect was apparent. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167783 12th Sep 2012 7:27am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Is this on a TD5 or TDCI?
I had the ABS/TC light appear on my TD5 and it turned out to be a poor earth in the seat box. LR have 3 earth pins in the painted seat box and hope that it will earth to the chassis in some way.
For me it was an easy fix, I ran a wire from the earth pins to the chassis and it was solved as easily as that.
HTH
Ben 2002 Defender 110 DC
Post #167791 12th Sep 2012 7:49am
Waldo
I don't surpose you could post a picture of where these earth pins are.
Had a similar problem myslef.
Will Defender 90 XS TD5 (03 Reg)
Post #167812 12th Sep 2012 9:27am
ben_j85jty
They are in the seat box under the drivers seat.
They are under the ECU I believe. 2002 Defender 110 DC
Post #167868 12th Sep 2012 5:08pm
This might help - the green circles show two of them in the floor of the seat box:
 Darren
Post #167878 12th Sep 2012 5:50pm
Waldo
Excellent thanks a lot, will check them tomorrow
One last question.
Do you know the location of the earths for the heated front screen?
Post #167995 12th Sep 2012 10:44pm
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
HTH
Ben
Hi,
Where exactly the chassis part connect to? Bow down
Post #469955 6th Nov 2015 6:23am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Just had the same problem.
Mine was a broken ring terminal on transfer box earth. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #469957 6th Nov 2015 6:58am
