Home > Technical > Rear Brake Problem - MOT Failure |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
Oil on the disc? I recently had a hub seal leaking leading to a rather alarming pull to the left under braking.
11th Sep 2012 7:24pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
I'l take a look and give them a good coat of brake cleaner |
11th Sep 2012 7:36pm |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
Bleed the lines as well, if nothing else it's a good reason to get up close and personal with the system.
11th Sep 2012 7:42pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17207 |
Pistons sticking in the calipers?
11th Sep 2012 7:44pm |
