Home > Technical > 12v timer for my webasto project
T1G UP
i need a timer to activate the fan on the 110 once the webasto has fired up.
when the webasto fires i want an adjustable timer so that after 5-10 mins the fan starts. it can stay on until the webasto shuts down.....just in case i don't use the vehicle or the RF is accidentally activated.
i've found this but i think its the wrong what round for what i require http://cpc.farnell.com/cebek/i-3/12v-adjustable-timer/dp/HK00447
Suggestions please.
Post #167001 8th Sep 2012 9:42am
Marcus
looks ok ... but will 5amps be enough ?
have you thought about a hrw relay .. they have timers, i'm not sure if they are adjustable
why not find a webasto timer on the bay ?
Post #167005 8th Sep 2012 12:12pm
dgardel
Italy
Re: 12v timer for my webasto project
Suggestions please.
is it the water webasto? it start the fan itself when the water reach 47 °C Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #167007 8th Sep 2012 12:30pm
T1G UP
Suggestions please.
BP- i think your getting confused with a timer to actuate the webasto itself. As for a hrw relay the front relays are 15 minutes i think. want an adjustable relay.
dargel- a Z has no facility as far as i can see. there are only 3 wires, pin 1 start pin 2 diagnostic and pin 6 fuel pump.
this is informative http://www.autoshop101.com/forms/hweb2.pdf idiots guide to relays
Post #167020 8th Sep 2012 3:23pm
T1G UP
Sorted Thumbs Up Two of these in series will do it. first one set for 10 minutes after the webasto starts this in turn powers a second one to go off after 30.
http://www.wolstentech.com/products/timede...ctions.php
Post #167021 8th Sep 2012 3:42pm
dgardel
Italy
Marcus,
see this one http://www.autoelettric.com/index.php?page...p;Itemid=3
I used it a lot
here the Tech data http://landrover.livedrive.com/item/0dbc40...829abe9c43 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #167028 8th Sep 2012 4:15pm
T1G UP
dgardel wrote:
Marcus,
I used it a lot
Excellent Smithers Thumbs Up i knew i'd seen a relay with adjustable timing dials built in the top Bow down
i'll get them on order
Post #167029 8th Sep 2012 4:26pm
