![]() | Home > My Defender > Swedish 110 td5 |
Nilsson Member Since: 02 Sep 2012 Location: Kiruna Posts: 12 ![]() ![]() ![]() |
Hello
Bought a 110 last year in march and have done some work in. Thought you people would like to see it ![]() This is what I had at the beginning ![]() Click image to enlarge Removed some stuff from the inside... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Stripped the back.. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Renovated the back seats, washed the fabric and replaced the cardboard with an aluminium plate. ![]() Click image to enlarge Sound and heat insulated everywhere I could ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Fitted a new backdoor trim and built a box for fuses and relays. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge New carpet because the old one was quite disgusting ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Mud console ![]() Click image to enlarge ![]() Click image to enlarge Built a roof rack, fitted a snorkel and a snow cover. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Questions? ![]() More pictures to come as the work goes on ![]() |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
Quite a range of skills on display there
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
And also, I have found out where the odd bit of carpet I have goes..Over the rear wheel arch and under the seat (7th picture down, RHS where the cup is
![]() Regards John M0VAZ Econet Station 48 no clock |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
Good work
Thanks
Its a cable for the lamps on the roof rack. It runs from the electric box under the cubby box to the engine bay and through the snorkel |
Not a bad idea on the cable routing, If and when I get a snorkel I was thinking of using the hole in the wing that currently has the radio aerial and running wire through there and moving the aerial to the roof bar
Good pics with the Nikon camera 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
The lights worked
![]() ![]() Click image to enlarge |
Did you have to cut the dash to fit the mud console? 1999 Defender TD5 110
Yes, you can see the cut in these pictures ![]() Click image to enlarge ![]() Click image to enlarge |
Thats a shame, I was hoping not to have to cut the dash to fit it
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
It almost annoys me my car is new and nothing needs doing. I want a project car!!!
FG Member Since: 01 Apr 2011 Location: Somewhere on the Swedish East Coast Posts: 63 ![]() ![]() ![]() |
Snyggt jobbat!
![]() /FG |
Tackar!
![]() Started to work on some wing top and hood protectors today ![]() Click image to enlarge |
Nicely executed
