![]() | Home > Technical > What is this tube for? |
Mine is a LH drive Puma 2.4. About right under the driver position location is a little tube sticking out of the car bottom, which must be a drainage tube I think. What is this exactly?
My first thought would be the airco drainage, but from a previous thread I understand that that is some kind of teath located above the front end of the gearbox somewhere up in the gearbox tunnel. The position of this little tube is also quite far back from where the airco compressor sits. Anyone knows? Here is a picture. ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Battery breather. Steve.
Right, that makes sense from a location point of view. Tks You never actually own a Defender. You merely look after it for the next generation.
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
It's an escape tunnel for the ubiquitous Land Rover spiders for when owners get carried away and threaten to use a vacuum cleaner inside their Landy.
Glossy rust
![]() No, high quality Dinitrol job ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
