Home > Technical > scan gauge 2 fuel consumption
LR90XS2011
Took the 90 for a drive with the scan gauge connected and it is showing between 4 and 14mpg which is clearly incorrect anyone on here with one know how to re-calibrate it
thanks in advance Rob DEFENDER 90 TDCI XS,
Post #165989 2nd Sep 2012 5:37pm
familymad
Hope it's wrong or I'm out! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #166194 3rd Sep 2012 7:34pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
hi,
I am also using the scangauge and also do not think that fuel consumption is correct !
but no idea what to do !
As late as possible, I will use it for code of defect
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #166297 4th Sep 2012 12:51pm
Tony
United Kingdom 2012 Defender 90 Puma 2.2 SW Keswick Green
Hi,
I've just fitted one this morning so will be going through the fuel calibration process next time I fill the tank up. How did you calibrate it initially - did you go through the process in the instructions when you filled the tank?
Cheers Thumbs Up
Post #166305 4th Sep 2012 1:33pm
Phil VM2.5
hi,
yes, I did as descripted ...
I wonder if the filling procedure is something to do with instant mpg
I am also not doing same road all the time, it can be highway , city, ....
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #166307 4th Sep 2012 1:43pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Did you set the engine size and diesel type according to the manual (Basic Setup Parameters, page 11)?
MPG accuracy is not perfect but nowhere as a far as 14MPG, at least in my case, and it improves with subsequent fill-ups if you take the time to adjust the volumes of fuel to help calibrate the scangauge (Calibrating the ScanGauge, page 20)
Post #166312 4th Sep 2012 2:00pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Mine is spot on every time.
I never used a calibration procedure, just put the parameters right first time it is powered up(engine size, tank size and diesel type) and at each fillup log the liters put in. Since then it is working a perfect.
The only nasty thing is that when idling the consumption goes up and you need to drive a bit to get it down. The further you are in a tank/ the more fillups you have logged, the quicker it gets back to normal values after idling and the less variation you will notice / the more precise short trips become.
Smile
Post #166313 4th Sep 2012 2:01pm
LR90XS2011
all thanks for the responses I think I will do a reset and start again see what happens DEFENDER 90 TDCI XS,
Post #166324 4th Sep 2012 3:14pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Topic Hijack...or not
Had my fuel breather pipe broken for a while, need to reset the fuel consumptions and can't find out how... Embarassed
How do I reset the scangauge? I did read the manual but did not find... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #280486 7th Nov 2013 11:50pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
The calibration is so you get an estimate of fuel remaining in the tank an does not affect either real time, or average fuel consumption. It uses inputs, speed, distance and fuel rate flow from the vehicle's engine sensors to calculate your consumption. It's a bit of a shock seeing those mpg figures in front of you isn't it?
Post #280797 9th Nov 2013 5:22pm
lrmaniac
Hi
I've reseted my scangauge but can't seem to reset the litres on fillup...
I've had a problem during the summer, on the fuel breather pipe and was unable to fillup the tank for a few months till get it sorted...
Now on fillup the other day the scangauge states I've filled uo 450L! Shocked wich might be true because I never set them to the right amount in the meantime...
Now, the only way to tell the scangauge the right amount of fuell in the tank is to let my finger on the < key till it reaches 65 wich I recon it would take me about half an hour? Can't I reset this item? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #284976 24th Nov 2013 10:34pm
