Home > Puma (Tdci) > exhaust manifold allignment
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Hi
I have had a lot of troubles fixing the leak between turbo and manifold. It appeared that the surfaces had to be machined - taking about 1,5 mm of each side. Now when I was about to fit it all again, I noticed - placing the manifoldgasket on the manifold, that the manifold appears to be shorter - and the bolt holes are a bit of center. 3 of the bolts was very bad looking when I took it of - had to redo the thread in the top. Now I am wondering if I need to buy a new manifold or machine the boltholes a bit to make it fit properly. I have a remap by Alive - but should that cause that much heat??
I have ordered a decat pipe - hoping that will keep things a bit cooler.
Best regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #165894 2nd Sep 2012 9:34am
T1G UP
edited
Post #165897 2nd Sep 2012 9:58am
CRJ
Some pictures
][/img]
Best regards
Christian
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #165899 2nd Sep 2012 10:09am
CRJ
Just a thought - could it have been caused by driving with faulty wiring to turbo?
And if I need a new manifold - is that obtainable from Ford - or is it special for the def.
Best regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #165900 2nd Sep 2012 10:20am
CRJ
I was thinking about cutting the gasket in two - thus allowing it to fit. Drilling the holes a bit, and machine the openings in the two inlets near the turbo ( it is those two that has "warped"). That will cause the holes for the bolts to be bigger than the bolt itself - do not know if that will be a problem. Any ideas?
Still worried about what could have caused that much heat? -
Best regards
Puma 130 - 08- sold
110 CC 2003
Post #165949 2nd Sep 2012 3:47pm
wslr
I think it is probably a combination of things, not just one.
It is worth de-catting the vehicle, as I'm sure this alone is the biggest issue. Hot exhaust gasses can't get out past the turbocharger fast enough because of the back pressure leading into the cat and the standard exhaust system.
Now, with this, any rapid cooling (anything from water immersion to driving down a long hill with foot off the throttle for a while) will cause the manifold gasket to leak, and perhaps this is more of an extreme issue in your part of the world?
Post #166032 2nd Sep 2012 7:16pm
