Home > Maintenance & Modifications > Spot / fog light switches |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 424 |
Just found out that the front switch is a latching switch
The rear fog switch is a momentary on which switches an ECU connection So I guess the answer is no I can not use the rear switch to control Spot Lights Would the rear demist switch work ? Any other ideas or do I have to spend the £50 |
1st Sep 2012 10:29am |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
What about
http://www.land-rover-parts-shop.com/en/ui...&stp=s Part number AMR6104 It could then fit behind the wiper stalk like in the Tomb Raiders - mine is wired up so that when off, the spots are off, but when its on the spots only work with the main beam. I can try and grab a photo if it makes it clearer |
1st Sep 2012 10:59am |
Thanks Alex
They would do the job Is there enough room in the stalk for it to fit ? A photo would be good. I like the fact that the genuine Land Rover part is £100 and the Allmakes is only £10 |
1st Sep 2012 11:05am |
There you go...
Looks like there is a fair bit of space still there (although it seems all LR's are made differently (!)). The steering column has (by the looks of it) had a hole drilled through the plastic for the extra switch, but this is covered by the rubber grommet that comes with the switch Click image to enlarge Click image to enlarge |
1st Sep 2012 11:35am |
It may be worth a chat with Andrew @ Defender Bits as he seems to stock a similar item and may be able to help...
http://shop.defenderbits.co.uk/defender-li...-624-p.asp Although my one only has 2 options (on/off) but the above are (sidelight,headlight/off) it would seem (!) |
1st Sep 2012 11:40am |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
Hi Gavin,
What about a simple Carling switch? Devon 4x4 have them on the shelf. Regards, Mark P.s. getting really excited about the Northern Lights trip now! |
1st Sep 2012 1:19pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Carling switch are a different size.
We have some genuine switches down at our lockup. Brendan |
1st Sep 2012 1:53pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
Have a look at this - http://www.defender2.net/forum/post164854.html#164854 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
1st Sep 2012 1:55pm |
Would a Carling switch fit in to the space for the electric windows - mine are wind up windows |
1st Sep 2012 3:00pm |
I found this picture of ARB Locker (Carling) switches, fitted into the electric windows switch positions - . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
1st Sep 2012 3:28pm |
mobilecentre have a good selection of switches, some with indicator leds
1st Sep 2012 5:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6074 |
That extra switch is available in 3 or 2 positions... 3 position for off/side/main beam, the 2 position ones were also used in early 90/110s for the rear fog lights, so the icon on the plastic "lever" bit is slightly different. |
2nd Sep 2012 7:33am |
