Home > Wheels & Tyres > Spare tyre compatibility
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
I have just purchased a set of 4 boost alloys fitted with General Grabber TR 235/85/16 tyres for my 57reg Defender 90. Would it be safe to use the old Michelin 7.50 R 16 as a spare until I can accumulate the funds to purchase another boost alloy and tyre?
Willie Defender Virgin
Post #16513 9th Oct 2009 10:52pm
MK
I believe they are the same diametre. So, yes. Puma 110" SW
Post #16514 9th Oct 2009 11:23pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Try this,
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16521 10th Oct 2009 10:31am
Willie
Thanks Fekete,
Tried web site but couldn't put in 7.50 R 16 tyre size, but could see how calculator worked.
Thamks Willie Defender Virgin
Post #16523 10th Oct 2009 11:01am
roel
Just measure it. Whistle Roel
2003 90 Td5 (2009-now)
Post #16535 10th Oct 2009 4:08pm
Glynparry25
As a spare it will be fine- but when I say spare it will be ok to drive to the nearest garage to get the other repaired
Glyn
Post #16536 10th Oct 2009 4:19pm
Willie
Thanks for the responses everyone. Just one thing more, when I got the wheels they came with wheel nuts. Only thing is there are two different types, one has a dimple on top of the stainless cap the other is flat. Are they the correct fitments? they look slightly different at the screw but both have the correct thread and fit a 27mm wrench.
I will try to post a picture latter.
Post #16541 10th Oct 2009 5:52pm
fekete
It mite be that the one with the dimple is the locking wheel nut, see if the one with the dimple on it, That a cover pulls off it Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16542 10th Oct 2009 6:15pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
The ones with a dimple are the locking wheel nuts, the stainless outer that has the dimple is just a cover that pulls off Thumbs Up
Post #16543 10th Oct 2009 6:16pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Yup - the dimple signifies the security bolt. Have you got the correct security attachment? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #16552 10th Oct 2009 8:20pm
Willie
Thought of that, but the covers wouldn't come off. I will try to pull it off (if you pardon the expression) a bit harder tomorrow. The nuts didn't come with a locking/unlocking key.
Post #16557 10th Oct 2009 11:12pm
Glynparry25
Willie
Rolling with laughter Rolling with laughter Pulling off and nuts in te same post! Rolling with laughter Rolling with laughter
Glyn
Post #16558 10th Oct 2009 11:14pm
fekete
Willie
Thumbs Up Rolling with laughter Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16562 10th Oct 2009 11:24pm
RED-DOT
I you can't remove the cap with the useless black sleeve simply turn it with your wheel key and it will come off (in your hand)!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #16565 11th Oct 2009 10:05am
Willie
Despite all the pulling and twisting the caps do not come off. I have measured them using a vernier and the dimpled (10 off) and the flat ones (13 off) are both the same - 27mm head, 29mm round shoulder and same thread. I can only assume they are an after market version. Looks like I will have to purchase a set of locking wheel nuts. Defender Virgin
Post #16578 11th Oct 2009 5:49pm
