Home > Maintenance & Modifications > Defender Squeaks and rattles
yorky
England 2007 Defender 90 Puma 2.4 SW Java Black
Now I know that part of the pleasure(?) of owning and driving a Defender is that you have to accept the noises that goes with it. I was told when I bought mine that a can of WD40 would be my best friend - not wrong! However, there is one annoying squeak that's really starting to get to me mainly cause I can't locate it! AND it doesnt do it when its raining or the road is wet. Sounds like its coming from under the dash at the drivers side as if its dry rubber on metal? I'm thinking steering column (but it probably isnt) Anyone had something similar Question any suggestions of new places to spray a bit of WD gratefully reveived. Thumbs Up 90 XS
Volvo V70
Post #164880 28th Aug 2012 12:35pm
SimonR
My best guess would be the inner wings (inner wheel arches) rubbing on something?
Si
Post #164908 28th Aug 2012 2:48pm
yorky
Thanks Si, I'll have a nosey around there. Obviously something that goes quiet when lubricated by rain/spray from underneath, but it sure sounds like its in the cabin - but can't be! Evil or Very Mad 90 XS
Volvo V70
Post #164937 28th Aug 2012 5:19pm
SimonR
Some noise is transmitted, particularly through the bulkhead so it sounds like its coming from inside!
I once had a noise which sounded like the little bells Morris dancers have on their shoes when I was accelerating. I was sure it was inside - and went to the extent of removing the dash from the bulkhead looking for such a bell!
About a year later, I crawled underneath (parked on a hill) and I heard the same noise as my shoulder brushed against the end of one front radius arm. It turned out that the washer on the end was loose when the bush was compressed. The rest of the time it was tight enough not to make a noise (and pass two MOT's). When the washer moved, it made a 'tinkling' noise! Tightened the nut a bit and the noise vanished!
Someone should compose a database of defender noises and the diagnosis!
Si
Post #164946 28th Aug 2012 6:03pm
yorky
It would be a lengthy tome! I'll keep hunting it down - like your noise it will be found eventually. 90 XS
Volvo V70
Post #164955 28th Aug 2012 6:45pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
I had a really annoying squeak, turned out to be a loose screw underneath the steering column fixing the shroud on - good luck
Also, check out the bonnet hinges and catch areas Wink 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #164977 28th Aug 2012 8:35pm
yorky
Did you get to it in the drivers footwell, behind fuse/relay box? or did you have to remove instrument binacle? 90 XS
Volvo V70
Post #164986 28th Aug 2012 8:53pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
I had a really annoying squeak, turned out to be the ex wife, she's gone, squeak stopped, result Thumbs Up 2007 TD5 90 Hard Top
Post #164990 28th Aug 2012 9:01pm
Tjhappel
United States 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I had a very similar problem, nothing in the rain or when damp, really loud when dry and it sounded like it was coming from the dash area. It was worse on bumpy roads etc... A buddy of mine finally rolled the window down and held the hood while I was driving.... Like magic the noise stopped! It turned out I just needed to lubricate the hook and hinge that holds the hinge on. It took me like 4 fing months to stop that damn noise. Hope this helps you,
Post #165027 29th Aug 2012 2:52am
nickh90
England 1989 Defender 90 V8 Petrol SW Auto Java Black
As above... 6 months it took me.. i stripped the dash out, window seals the lot..
Eventually found it the be the metal on metal for the hinge and hook on the bonnet.. annoying as hell but glad i found it. Quick squirt every few weeks, problem solved..
Post #165034 29th Aug 2012 6:39am
My steering wheel was originally rubbing on the plasting casing of the column surround and squeaking when the wheel was turned. Adjustment the casing sorted this.
Post #165038 29th Aug 2012 7:16am
nidge n
ive got a squeak that sounds like its coming from the roof lining and or the door card. If i was a top secret agent and this was used to interrogate me you'd have all you need to know by now Rolling with laughter still love me car Thumbs Up
Post #165089 29th Aug 2012 12:47pm
yorky
been raining all morning, so of course no squeak! The bonnet hinges are suddenly becoming suspect #1 - as soon as it dries off I'm out there! Thumbs Up 90 XS
Volvo V70
Post #165097 29th Aug 2012 1:29pm
yorky
Success, looks like it was the bonnet hinges!
After the earlier posts I sprayed a bit of WD on them and as today is the first dry morning went out for a test drive and hey presto - no squeaks! Amazing how sound travels and leads you down the wrong path, no doubt why you have to be quiet in a submarine!!
Thanks to everyone for their inputs. 90 XS
Volvo V70
Post #165548 31st Aug 2012 10:39am
nidge n
Well done, there's nothing better than finding a rattle Thumbs Up
Post #165549 31st Aug 2012 10:52am
