Home > Puma (Tdci) > First fault
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
First fault
Yep got the first fault, minor but I suppose I will need to get it sorted. Engine suddenly turns into a 300tdi for 5 seconds usually when changing gear at low revs. Plenty of others had this as well but no definative fix mentioned , I presume it's the fuel PRV but if anyone can nail it down with a specific fix it will save me some time. not a big deal but next time I 'm passing the dealer I'll get them to have a look Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #16451 8th Oct 2009 9:18pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
That sounds like the same problem that I get occasionally. I have taken the lazy approach of keeping my revs fairly high for the first couple minutes of driving and then all is well. A fortnight ago before I had adopted the higher-rev driving style I encountered the problem for a little longer then usual and it triggered the engine warning light and emergency mode. When Land Rover Assist arrived it had thrown up a 1169 error code, but a quick reset of this, and crimping the terminals on the fuel rail sensor seem to have sorted it. I intend taking a similar approach when I'm passing the dealer. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #16453 8th Oct 2009 10:17pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
The new tune patch is supposed to fix this problem. Good Idea to see the dealer
Allan
Post #16457 9th Oct 2009 2:19am
chalky
Sounds like something i had !
Turned out to be the EGR valve that was dodgy !
And ive had the dowloaded patch to the ECU it totally transforms the driving throughout the rev range. DEFENDER XS CSW 08 TONGA GREEN
Post #16475 9th Oct 2009 8:56am
willy eckerslike
Thanks for the replies, i'll post up my findings once i've been to the stealers Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #16496 9th Oct 2009 12:22pm
