Home > Puma (Tdci) > Defender recall on seat belt nuts |
Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
22nd Aug 2012 8:55pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I'm a bit concerned about what collateral damage might get caused here. What part(s) exactly are the 'side runners'? Do you mean the steps? Pete |
22nd Aug 2012 9:56pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
That's because your's is a 110 Tim John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
23rd Aug 2012 8:29am |
According to my recall letter, some 110's and 130's are also affected.
Pete |
23rd Aug 2012 8:35am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
The boys must have picked up the bolts for mine from a different box then California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Aug 2012 9:28am |
Ah, didn't know that. I feel left out now as well John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
23rd Aug 2012 9:44am |
pierrej Member Since: 21 Jul 2012 Location: Perth, W.A. Posts: 16 |
Got my rear high level brake light sorted, and was told they had completed this recall as well. Was nice to see a bit of effeciency from a workshop, especially because I was also not aware of this recall.
24th Aug 2012 3:11am |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
Had mine done yesterday whilst it was in for a service. Side runners did not have to come off on mine . They just changed the lower bracket bolts that holds the belt 'reel', near where the backrest adjust handles are 15 plate 2.2SW XS
25th Aug 2012 9:55pm |
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 |
Received the letter end of last week .... Will take it in next week Wednesday ... and while they are at it, they are welcome to also check this stereo thing that simply just cuts out every now and then or stops working for a couple of days for no obvious reason and then suddenly goes back to normal as if nothing has happened ... still refusing to play any kind of self-recorded CDs - no matter what format, though ... Best Regards,
Axel |
27th Aug 2012 3:34pm |
Just had mine done. Took about an hour and the side steps did indeed have to come off.
Pete |
29th Aug 2012 9:50am |
A bit more info:
Recall reference: P025 Models: Defender (Including Defender 90 & 110 Chassis Cab, Truck Cab, Soft Top, Hard Top, Pick Up, High Capacity Pick Up vehicles and 130 Double Cab Pick Up). Launch date: 08/08/2012 Numbers involved: 5987 Build start date: 01/02/2010 Build end date: 31/01/2012 Concern: SEAT BELT MOUNTING BRACKET MAY FAIL Description: It has been identified that some seat belt mounting bracket bolt/studs maybe out of specification. The bolts may have suffered Hydrogen Embrittlement during their production. Occupants will normally notice the failure by the looseness or detached seat belt brackets. However, if the issue is not rectified, then the occupant will not be restrained in their seat if the vehicle is involved in a collision. Remedial action: Recall all affected vehicles and replace the seat belt mounting brackets. Pete |
29th Aug 2012 12:44pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
According to Topix my 90XS has a build date of 11 Feb 2010 and yet there is no info on Topix recording a recall. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
29th Aug 2012 5:12pm |
Jonno Member Since: 06 Mar 2012 Location: Yorkshire Posts: 234 |
Well just had mine done on Friday and after having a look underneath they have added / changed a substantial metal plate that bolts to the floor and chassis rear outriggers. I,m not sure if the bolt sizes have increased, but there was a bit of swarf floating around the floor afterwards indicating the floor holes have been enlarged.
They also seem to have added some rubber pads between the outrigger and the new bracket. I'm not sure if the previous plate conected to the outrigger or not, maybe somebody who has not had it done could say. it took the garage about 20 minutes in all to complete the work. I did take a pic but my old mac doesn't seem to want to allow me to upload it ! However the link below should take you to photobucket: https://s3-eu-west-2.amazonaws.com/i.hubnu...46e46c.jpg Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Sep 2012 1:26pm |
