Home > Maintenance & Modifications > Front propshaft issue with defender 110 td5!!
Welshsurferdude
Wales
Hi there
I have a Defender 110 crew cab on a 02 plate with a 2" lift. it also has 295/95/16 tyres with spacers.
They said that the front prop is worn/noisy and its a Disco 2 TD5 prop with double cardons and needs a new one so I ordered the following
http://www.island-4x4.co.uk/propshaft-fron...-1179.html to replace it.
got delivered this morning
But the garage says this doesn't fit.
Whats the issue here?
I can't go see the car as Im stuck at home with a broken foot!
whats the correct prop or advice on the best prop?
Many thanks!
Kenny 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #163748 22nd Aug 2012 4:29pm
The Disco Td5 prop uses a different sized drive flange on the transfer box. It's bigger (in diameter) than the one that will fit the propshaft in the link you posted.
You just need to get a "normal" Td5 defender drive flange for them to bolt in place, which is either FRC5442 if you have a 32D suffix transfer box, or a IEC100020 if yours is a 43D suffix (I don't know what the difference is between then, I though they were all the same!)
And beware of the propshaft you've bought... looks l ike a Britpart one.... best carry a spare!
Post #163796 22nd Aug 2012 7:10pm
Porny
Site Sponsor
If you've got a 2" lift... I wouldn't replace the propshaft with a wide angle version, I'd get another double cardon version - as per the Td5 Discovery one.
The wide angle one is good for droop, but with a 2" the working angle of the UJ when on the road will be too much, and you will get a vibration.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #163891 23rd Aug 2012 6:25am
Welshsurferdude
Wales
Thsnk you for your advice boys!
I thought this might be the case! 2008 Santorini Black 110 XS USW (Sold)
Post #163893 23rd Aug 2012 6:55am
