Home > Puma (Tdci) > Swivel |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Hi boy i've had 3 swivels replaced, And 1 swivel ball the swivel ball had a machine mark in it which made 2 of them leak the other 1 just must of got behind the seal.
All replaced under warranty NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
5th Oct 2009 8:59am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
5th Oct 2009 9:11am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Thanks buddy, just rang them and I am booked in on the 19th. Hope there is anough oil/grease in it to last that long.
Boy |
5th Oct 2009 9:16am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Hi Justin,were have you been hiding? it doesn't take much for something to damage the wiper seal when off roading and it's covered by the warranty. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
5th Oct 2009 10:09am |
Did some offroading in spain (mostly dusty tracks) a couple of months ago, some gental green laning last month and last weekend went to Exmoor with the LRA crew but all we did was ariver crossing at Tarr Steps. The seal seams to have gone at the rear most point of the ball. Maybe a small stone/grit got in?
5th Oct 2009 10:18am |
Yes there should be and if not on inspection the dealer will sort out if it has caused any other damage i've ran 3 weeks with 1 leaking The other thing is make sure that the brakes haven't been comtaminated NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
5th Oct 2009 10:45am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Can I ask how does one check the level of grease in the housing and how do you refill it? Puma 110 - gone
Series III 1973 - going strong |
7th Oct 2009 5:28am |
Square head plug on top of the housing for the oil James. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
7th Oct 2009 7:30am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
You can not check the level. Puma 110" SW ............................................................. Earth first. Other planets later |
7th Oct 2009 1:47pm |
