Home > Maintenance & Modifications > alive intercooler
Tim seymour
Australia
alive intercooler
Hi i just brought a alive intercooler and a atric remap for my 2007 defender and was wondering how hard is it to fit the intercooler can is there anything i shoud know before i start cheers Razz Cess the Taswegian
Post #162494 16th Aug 2012 10:53pm
bell-auto-services
The intercooler should be a bolt on fit so should be straight forward a swap. Make sure you get the hoses on fully before you do up the clips and keep the cooler pipes and internal hoses free from oil before refitting.
Pete
Post #162495 16th Aug 2012 10:58pm
Tim seymour
Australia
thanks pete should a walk inthe park cheers tim Razz Cess the Taswegian
Post #162496 16th Aug 2012 11:29pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Pete
Hi Pete
Would like to find out myself for when my turn comes to upgrade.
I have A/C and had a look the other day but it looked like you will have to remove A/C radiator???
And how do you remove the crossmember(or whatever you call it) that covers the radiator and intercooler? Looks like there are bolts in the fenders behind the headlights that needs removing?
Please shed some light for me!
Post #162510 17th Aug 2012 7:06am
Denis
Russia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
I fitted Alive intercooler with silicone hoses myself on Puma 2010my with a/c.
In general you have to follow workshop procedure, but not exactly Smile
Sequence was:
1. radiator grille
2. fan housing (only upper part)
3. hood latch panel - you have to remove 2 studs - № 18 on picture - it wasn't very easy... I used some type of claws (vise or clamps?) then I changed that studs on M8 bolts
4. old intercooler with hoses
before I fitted new intercooler I had to do 2 things :
1. lessen 2 bolts on A/C radiator and slightly push A/C radiator forward
2. remove plastic outgrowth on left binding (?) of the main radiator. That plastic outgrowth didn't let the new intercooler to fit vertically
Also, it was more convenient to fit hoses after new intercooler bolted in place.
Keep in mind that it is only my experience and all Defs are hand made so yours may be slightly different Smile
Cheers Puma 110
Post #162654 17th Aug 2012 4:02pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Denis wrote:
...on Puma 2010my with a/c.
aha...I've searched the workshop manual but could not find that procedure, can you point me out on wich page it is?
Thanks! Thumbs Up Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #162657 17th Aug 2012 4:19pm
dgardel
Italy
remove the studs "18"!!!
When you will re-install use normal (SS) screws, so in the future will be more easy for (eventually) maintenance Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #162662 17th Aug 2012 4:39pm
Denis
Thanks! Thumbs Up
"303 Engine"
then "303.12 Intake Air Distribution and Filtering"
then begins with "Charge Air Cooler (19.46.19)" Puma 110
Post #162663 17th Aug 2012 4:46pm
dgardel
Italy
Also right hand intercooler support, looking the front of the car
and, probably it is necessary to cut (I cutted it with dremmel type tool) 2 not used plastic support (on the water radiator)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #162664 17th Aug 2012 4:50pm
