Home > Puma (Tdci) > MY12 110 2.2 REV PROBLEMS
keith
Hi my brand new 110 xs 2.2 is a terrible drive . when i release the throttle the revs stay on for 3 seconds and when i depress the clutch the revs stay up for 3 seconds . This makes driving almost impossible and gear changing like a 1940s tracktor . When driving at normal speed the vehicle starts sputtering as though its lacking air or fuel .No faults are showing on the dealers diagnostics yet this cannot be normal . Any ideas on this new 2.2
Post #162199 15th Aug 2012 8:46pm
110SEB
Keith get REALLY stroppy with your dealer and get them to come out with you on a drive until the problem shows. Good luck.
Post #162200 15th Aug 2012 8:51pm
ericvv
Re: MY12 110 2.2 REV PROBLEMS
3 seconds sounds a bit too much, but it indeed takes a bit of time to get used to the electronic throttle of the Puma. There indeed is a delay in response to releasing the throttle, and this basically means that before changing gears, you have to first releast the throttle, wait a second or so and then depress the clutch. You will never be able to change gears fast, this is no eurobox or sportsbox, you have to give the mechanism time to do what it has to do without forcing.
It took me several weeks to get used to this electronic throttle and the delayed response, but once you have understood it, and provided that you agree to change gears not fast at all, it becomes a gem to drive.
The sputtering however at normal speed, no idea what that can be. Again, avoid to handle the throttle too brutally, maybe that will help. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #162201 15th Aug 2012 8:54pm
keith
Keith
Thanks for the positive reply . Yep the release of the throttle first then a wait before changing seems to work , strangely the factory asked what i was used to ( TD5 ) and said to change my driving style , that this was the new engine managment system of 3 seconds hold on the rev drop . weird . the TD5 was slick smooth and lovelly in comparison . i find this new 2.2 very difficult . And whats with the exessive blowing noise from the air intake ? its like a burst exhaust
Post #162205 15th Aug 2012 9:09pm
bob neville
Keith
Air intake noise could be the air filter box top is not fitted correctly. They can be a Censored to seat correctly.
2013 Defender 90 CSW - sold
Post #162210 15th Aug 2012 9:21pm
dgardel
Italy
Check the clutch switch (pressure operated switch on the clutch pump, engine bay) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #162318 16th Aug 2012 11:52am
RobKeay
I found not fully taking my foot of the pedal helps to make the smoother. Just apply a tiny bit of revs.
Post #162356 16th Aug 2012 1:51pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Mines exactly the same...very annoying and results in a terrible gear change.
Post #162675 17th Aug 2012 7:01pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i experienced the same, with the late'ish 2,2 clutch release but i've got used to it now, i never change gears fast.
the 2,4 did not have this as new but in the meantime with 80'000 on the clock and still running with the first clutch your forced to change gears slowly anyway. LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #162742 17th Aug 2012 10:34pm
