Home > Maintenance & Modifications > Lighting - Wipac crystal and relays?
NoDo$h
Spotlamps are good. We like spotlamps. Sadly they are only any good when on main beam. So having cracked one of the standard 7" lamps (the ones that are pretty much unchanged since Boudicea first mounted them on here chariot), I started sniffing around for replacements and came across the Wipac Crystal lamps. Because they use a revised reflector with clear glass, the beam pattern and projection appears better based on the various pics I've seen, with a nice clear cutoff so you don't dazzle other drivers. They're also e-marked, which is nice.
While sniffing around I also came across the suggestion to run the lighting circuit through relays with a decent direct feed from the battery to reduce voltage drop. Seems a simple enough solution and waterproof boxes are easy enough to pick up in Maplin / RS et al.
Anyone on here tried either or both approaches? I've not checked to see what the voltage drop is on our 90 yet, but will make a note when I do and post back here before I start buying relays and rolls of cable.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #1561 4th Mar 2008 1:27pm
NoDo$h
Crystal lamps ordered from Paddocks. I'll look to fit them at the weekend and try and do some comparative photos of the beam pattern.
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1577 5th Mar 2008 1:20pm
JSG
Re: Lighting - Wipac crystal and relays?
The lighting circuit should be via relays anyhow - I guess the feed idea may improve things.
Post #1579 5th Mar 2008 6:12pm
NoDo$h
Can't find any reference to lighting relays in the handbook Confused I've had a good rummage but I can't find it under battery, fuses or lighting sections Embarassed
I understood one of the problems/weaknesses with the Defender lighting circuit was that the switch carried the full headlamp load. If that's not the case on 07 models then happy days Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1581 6th Mar 2008 10:17am
JSG
Really? You may be right - I'd assumed there were relays as it is standard practice on most vehicles these days and has been for some time.
Need to investigate I reckon.
Post #1585 6th Mar 2008 2:15pm
NoDo$h
Unfortunately I won't be able to poke around the 90 until the weekend when I fit the lights.
As mentioned above, I'll post some comparative pics and some voltage readings and if it warrants it (and they aren't already fitted) will look at relays providing more direct current to the lamps as the next step. You're right, it's been standard on most cars for some years now, but then Defenders aren't "most cars" so anythings possible Confused
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1588 6th Mar 2008 4:00pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Fitted those new headlamps yet?
If so, do they give a better dip beam than the standard headlamps?
DAZ110
Post #1616 11th Mar 2008 8:56pm
NoDo$h
Sorry Daz, had to put this off until ths coming weekend. Will post as soon as it's done Thumbs Up
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1617 11th Mar 2008 9:06pm
DAZ110
No problem, I was thinking of getting better headlamps myself.
I'll wait until we have your opinion, once you have tried and tested yours!
With Thanks
DAZ110
Post #1618 11th Mar 2008 9:13pm
MPS4x4
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Orkney Grey
I tried the crystal lamps IMO waste of money no better than standard units. I have fitted IPF upgrade which consists of lamps, wiring loom and relays 100/170w bulbs. Brilliant but not road legal. Anyway passed Mot.
Post #1629 12th Mar 2008 10:24pm
NoDo$h
Swapped out the OE lamps today (Wipac Quadoptic) for the Crystals. Definitely a better beam pattern (more light thrown further) but as it's been hurling it down all day I haven't checked for voltage drop or taken the "after" photos. Really need to take it out for a drive on a clear night to see if it's a useful improvement or just looks cool Embarassed
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1647 15th Mar 2008 9:28pm
DAZ110
Any more news on the headlamp replacement, are they better than the standard lamps on dip beam?
Are they fitted on the land rover that was parked in that ditch last week!?
DAZ110
Post #1759 4th Apr 2008 1:02pm
NoDo$h
Definitely better on dipped beam, the light spread is better and projects further up the road (alighnment still the same, checked that when fitting) and yes, they are fitted to the LR that was "resting" in the ditch. We've since fitted Philips +50% lamps and Shocked it's like being in a normal car, only higher!
Still need to take some pics though. A little preoccupied building a treehouse (palace?) for Little Miss Do$h with every hour I've got outside work at the moment but will get around to it, I promise!
2008 D3 SE
2010 90 XS SW
2006 D3 SE - gone
Post #1775 4th Apr 2008 7:58pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Hi all...new member...might as well get straight into eh? Wink
There's a mob here that do light harness upgrades for Land Rovers.
www.traxide.com.au
I installed an early prototype trial for the bloke who runs the place on the Disco and it improved the light output by about 20% (measured with a light meter). Nice to have white light rather than yellow.
They seem to have developed it considerably since then including one for the Defender that gets around the burnt switch issue...also has a spotlight combination version.
One of the many weekend pastimes awaiting me when the new Defender arrives from the "Old Country"
Nice site chaps! Bow down Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #2032 6th May 2008 11:27am
