Home > Camping, Caravanning and Holidays > CTEK MXS 5.0 battery charger
WarPig
My Ring battery charger that I use for my caravan battery gave up the ghost recently Big Cry . In a way Im pleased as ive been wanting to buy a Ctek mxs5 for some time, but couldnt justify the purchase.
So Ive now bought one from Amazon for £54 and its the dogs danglies Thumbs Up . Nice small/neat unit with silent operation..
It gives an 8 stage charge..
Well worth the money :thumbsup:
Post #160835 8th Aug 2012 8:07pm
K9F
I've used an Optimate for the last 16 years on my motorcycle and it does the same thing. The Optimate is the same one all these years and I have only had to replace the battery on the bike once in all this time. The proviso is of course that the battery (unless it is maintenance free) needs to be topped up periodically.
Excellent product.....But now with version 6 I see. Mine isn't even labelled as version 1 it's that old, bit like me really! Laughing
http://www.amazon.co.uk/s/?ie=UTF8&key...paguadxo_e If you go through life with your head in the sand....all people will see is an ar5e!!
Post #160859 8th Aug 2012 9:36pm
T1G UP
I got the C Tek 7.0 will do AG battery and restore them . Very good piece of kit.
Post #160867 8th Aug 2012 10:16pm
ericvv
I have a similar charger, but Husqvarna branded, which I bought with my garden tractor, No problem to recharge the small battery in a 750cc garden tractor, and you can even leave it on there in the winter to trickle charge, but are these chargers any good to connect to a standard Defender battery for either recharging when necessary, or for contiuous trickle charging in the winter when the vehicle might not move for a week at a time? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160878 9th Aug 2012 4:35am
T1G UP
yes perfect for the look at the C TEK site. i have a second set of connectors that can be left on the battery so a quick connection can be made.
Post #160897 9th Aug 2012 7:49am
WarPig
Stage 8 of the Ctek is a pulse mode that keeps the battery topped up, as and when the level drops. I havent read my instructions fully, but I assume when its left connected to the Defender the battery doesnt need disconnecting from the vehicle?
Post #160912 9th Aug 2012 9:08am
T1G UP
nope
Post #160956 9th Aug 2012 2:45pm
WarPig
Thanks T1G UP Very Happy
Just had a little scare with my new charger. Last night I connected it to my old caravan 110 amp battery which doesnt hold its charge, and I was going to throw it away. This morning I went into the garage to check on it and I heard strange bubbling/gurgling noises, so I switched it off and checked it with my multimeter, which read 17V Shocked . I quickly ran away Embarassed
20mins later I rechecked the battery which read 10.9v, I reckon the battery is now dead, but what was happening during the bubbling/gurgling stage?
Post #160957 9th Aug 2012 2:52pm
T1G UP
it over volts the plates to get them gassing! thats part of the refreshing process. Read the book! For a straight re charge go to normal, for a flat or deeply discharged battery then go restore.
heres a link http://www.ctekchargers.co.uk/ctek-mxs-70.php
Post #160958 9th Aug 2012 3:05pm
I have the C-Tek plugged into the Jet Ski all the time in the garage, plug and forget Cool
Recommended Thumbs Up
Post #160960 9th Aug 2012 3:14pm
WarPig
But surely at stage 7 it shouldnt be putting out such a high charge?
So is the bubbling/gurgling noise from the battery considered normal? Ive just reconnected it to the same battery and straight away it started making bubbling noises, so I switched it off.
When doing anything electrical I always use the following formula..
Me + Electricity = brown pants Mr. Green
Post #160970 9th Aug 2012 4:08pm
T1G UP
just leave it to do its thing....you got smoke alarms right?
Post #161037 9th Aug 2012 10:20pm
