Home > Maintenance & Modifications > Stainless steel headlamp mounting rim - Mobilecentre
ericvv
Can anyone confirm that these are not only a straightforward conversion for standard Defender headlights, but also for the large headlight with the H4's of the SVX style front lights setup?
Here is the link to the item: http://www.mobilecentre.co.uk/index.php?ma...cts_id=616 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160569 7th Aug 2012 4:34pm
It should be okay but I couldn't guarantee it for you. Maybe you could ask for measurements from them direct? I am sure they would be more than happy to help Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #160576 7th Aug 2012 4:55pm
ericvv
Tried, but got an automated reply in absence back from Tim. He is out for the next week til after Billing. And their general e-mail address for questions did not answer. So will have to wait I guess. You never actually own a Defender. You merely look after it for the next generation.
Post #160577 7th Aug 2012 4:58pm
I would if I was you just in case. But I highly doubt they won't fit. As I mentioned before a few measurement will confirm it for you. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #160593 7th Aug 2012 5:55pm
ericvv
So nobody from the SVX/ICE drivers have replaced those rustprone OEM headlamp rings yet for SS versions Question
If anybody can confirm that Mobilecentre ones will be a straight fit I would order together with their SVX real LED indicators, otherwise I just wait to hear back from Tim after Billing..... You never actually own a Defender. You merely look after it for the next generation.
Post #160597 7th Aug 2012 6:08pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I thought my SVX ones were already stainless, but I'm not so sure now. If the surrounds weren't so fiddly to remove, I'd take one off to check.
I'd be interested to know if Tim's ones fit too.
Pete
Post #160654 7th Aug 2012 10:02pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
fitted a few of Tim's SS rim's to customers cars, be them , the LED headlights tho. Straight fit, has for SVX lights, i had SVX headlamps in my 110 before i changed to LED, and had no problem with the SS mounting ring on them either. I'll speak to Tim tomorrow and give him heads up on this post..............
Ada Putting Dreams on Drives at JLR Solihull..
Post #160661 7th Aug 2012 10:38pm
mobilecentre
Sorry for the delay we have been flat out getting a customers car ready then trying to get ready for Billing.
Stainless rings go straight onto a SVX headlight as it is still a PAR56 unit 7" lamp same as standard Thumbs Up
Post #160687 8th Aug 2012 6:34am
XS Pete
Cheers Tim Thumbs Up
Pete
Post #160708 8th Aug 2012 7:31am
ericvv
Tim, PM sent abt 2 items Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #160804 8th Aug 2012 6:12pm
