Home > Off Topic > Quesion to Radio comms type peoples
excossack
I have a ally telescopic mast that I use on some rallies such as WRC etc. The mast is about 20+ft tall.
Nornally have one antenna mounted to the very top. The mount has a built in three legged ground plane and normally has a MSA highband (160Mhz ish) whip installed.
What I would like to do, is add a 2nd antenna but on MSA lowband (86Mhz ish). Would this cause any issues when I come to transmit? (one radio at a time.)
My thought was to stagger the antennas so one is higher than the other
I might also add a scanner whip as a well. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #160625 7th Aug 2012 7:53pm
Glynparry25
I will PM you a load of information and a possible device Thumbs Up
Glyn Dog Sheep
Post #160741 8th Aug 2012 11:34am
