Home > Maintenance & Modifications > SVX style LED rear turnsignal
Page 2 of 2 <12
dgardel
Italy
Very Happy
see again PM and email
Big Cry Big Cry Whistle Whistle Mr. Green Mr. Green Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #160702 8th Aug 2012 7:21am
ericvv
mobilecentre wrote:
I have been through this a few times Thumbs Up
Unscrew the old lamp , plug in lamp screw new lamp in - less than a minute per side. We will supply gaskets which you would fit to the plinth but LR never bothered fitting them as standard.
The lamps are ECE homolgated for rear indicator and marked as such.
Take old flasher relay out and plug new one in Thumbs Up
Our flasher is fully electronic and flashes within the ECE designated rate, it is 3 pin so will work all exterior lighting functions including trailer electrics.
Our flasher is silent as you have visible warning on the dash of indicator operation so do not require audible.
Tim, have sent you a PM Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #160781 8th Aug 2012 4:48pm
ericvv
While I am awaiting Tim's shipment..., where is the flasher relay located? You never actually own a Defender. You merely look after it for the next generation.
Post #163307 20th Aug 2012 5:55pm
Top left hand corner of fuse box located under steering wheel
Post #163312 20th Aug 2012 6:00pm
ericvv
Post #163314 20th Aug 2012 6:04pm
dgardel
Italy
Re: SVX style LED rear turnsignal
wrong quote.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #163356 20th Aug 2012 8:14pm
ericvv
Post #163385 21st Aug 2012 3:58am
Page 2 of 2 <12
