Home > Maintenance & Modifications > lowering springs
Page 3 of 3 <123
Glynparry25
Killer90 wrote:
glyn do do you recon that works Very Happy
It works VERY well: http://www.youtube.com/watch?v=wUl4RbE3CNk ...... 8.6 1/4 mile!!
Glyn Dog Sheep
Post #160566 7th Aug 2012 5:31pm
Killer90
Site Sponsor
Shocked Shocked wow that is quick Shocked CSK Automotive
www.cskautomotive.co.uk
Post #160578 7th Aug 2012 6:10pm
farmer giles
the ride on the 300 is the best; the cornering is really planted even on 235/85s because it has the konis on it. The Td5 just had the spring drop but kept the factory shocks. Personally i think the shocks make far more difference than the lowering,
are you running gas shocks Chris?
Post #160698 8th Aug 2012 8:11am
Killer90
Site Sponsor
at the moment i still have the standards but was thinking of going for either the koni or fox shocks Thumbs Up CSK Automotive
Post #160788 8th Aug 2012 6:26pm
farmer giles
i don't think you will be disappointed with either Very Happy
Post #160892 9th Aug 2012 8:36am
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
Interesting stuff this.
We run a 90 on the full John Eales handling kit so slowered springs but not much higher spring rate and instead it's got very tight anti roll bars and Koni Raid's set to "punish spine" setting.
It turns in and drifts surprisingly well. For a 90 it's quite neutral.
Do you find you get tyre skip on poor roads if giving some mid corner? I've been thinking that the next front dampers I use I'll maybe wind things off a touch as you can end up skittering on the potholes like some sort of modern car with a smear of black for a tyre! 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #160920 9th Aug 2012 11:01am
farmer giles
hi phil,
i cannot recall any tyre skip, but on smooth wet tarmac the 300 tdi could drift on roundabouts when encouraged Embarassed I have spend 9 hours driving upto fort william and the journey was quite comfortable. This one also had uprated anti roll bars fitted.
the td5 was a harsher ride; 5 hrs driving to south Cornwall i was nowhere near as fresh as the 300 tdi long journeys.
J E Engineering did the suspension mods on both vehicles
Post #160936 9th Aug 2012 1:10pm
Page 3 of 3 <123
