Home > Technical > Think my defender has lost the plot..
Likeomg
as of late, my car has been doing all sorts... electrical..
the general is to do with lights on board systems etc, i think maybe there is something up with a door and where the switch meet..
can be driving along at night and both interior lights will start flashing on / off
when i walk away from it and lock it up, the alarm either goes off straight away or gives two beeps - if i unlock it and lock it again it works fine...
anybody got any ideas?
Post #159703 3rd Aug 2012 3:32pm
either water has gotten in somewhere or you are chaffing your loom somewhere.
is your truck garaged ?
has it been in an accident .. possible loom damage ?
any modifications to the electrics ?
Post #159708 3rd Aug 2012 4:13pm
Likeomg
Hi usually garaged at my house but when at our other house it has to be left outside
Other house being in the lakes, very wet...
Has minor modifications to the electrics, heated door mirrors, and washer lamp things..
Did have the full bulkhead replaced about 2 weeks ago... Maybe this has something to do with it, land rover had it for four weeks while they did it...
Post #159726 3rd Aug 2012 5:24pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Sounds like the door micro switch is earthing out intermittently, this would cause the interior lights to flash, the alarm to not set correctly as the door is seen as not closed and then give spurious alarms when it does set. I believe the alarm will use the interior light coming on as the sensor for if any door is opened. Darren
Post #159732 3rd Aug 2012 5:38pm
VeeTee
Netherlands
Correct. The door switches are part of the alarm circuit. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #159740 3rd Aug 2012 5:43pm
if you had the bulkhead replace under warranty, leave your truck with the dealer until they have finished the job properly
Post #159784 3rd Aug 2012 8:03pm
Glynparry25
Includes your back door and bonnet (but don't think the bonnet will activate light Confused ) Thumbs Up
Sit in the car and close all doors- make sure light is out- then give the doors a wiggle.... if the light comes on it is that door switch. If it doesn't at any point it is something deeper........ earthing out somewhere on the bulkhead.
As for the beeps- If you leave a door open and try to lock the truck, the horn will beep twice to tell you something isn't right..... I have done it a couple of times where the missus is taking her time getting out- she then thinks it is the truck hurrying her on!! Rolling with laughter
Glyn Dog Sheep
Post #159786 3rd Aug 2012 8:11pm
Likeomg
they had it 4 weeks Shocked
they sent a technical guy out to me tonight and a door switch had got jammed by the door seal, all sorted now.
Post #159820 4th Aug 2012 1:35am
