Home > Technical > Puma "Airbrakes"....
Page 1 of 3 123>
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I removed the "airbrakes" (rear mud flaps) on my Puma about 6 weeks ago, and now have slightly better fuel economy.. It's gone from just over 28MPG to almost 31MPG.. Not a huge amount, but over a year it will add up to be a decent saving.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #158860 30th Jul 2012 11:03pm
ajps72
2001 Defender 110 Td5 SW Chawton White
mmmm Doesn´t sound too bad, good Idea I will try removing mine or installing softer ones. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #158862 31st Jul 2012 3:55am
K9F
Think that's good? Try this.....
I fitted a Tornado GR Mk4 Aircraft nose cone to the front of my Defender and now I'm getting 82.3MPG.. Rolling with laughter Rolling with laughter
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #158864 31st Jul 2012 4:53am
come on Mal - let's have a photo
Post #158867 31st Jul 2012 6:11am
K9F
Steve, it makes me laugh! Laughing If people are prepared to go to such lengths to eek out an extra couple of MPG maybe they're driving the wrong vehicle in the first place. I'd rather keep the mudflaps and give other road users an element of consideration and protection of the extra crud I'm likely to be throwing at them (as well as my own vehicle) without them.
Get a proper remap to gain noticeable increases in performance and fuel economy if you can keep your right foot from using the extra torque. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #158869 31st Jul 2012 6:27am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Is that OK from a C&U perspective to drive around with them removed? I can't think of any other vehicle, execpt maybe tractors, where most of the rear of the wheels is exposed. It must throw load of crap out the back.
Regards
Pete
Post #158871 31st Jul 2012 7:28am
Regards
Pete
There is no legal requirement for mudflaps on the back of a Defender as far as I know, nor for that matter on any other non-HGV vehicle. There are more Landrovers on the road without mudflaps than there are with, and many (eg all military ones) leave the factory without any fitted.
If, however, you come back onto a public highway after driving off-road and either make an excessive mess on the highway, or bombard the car behind with crud, you are committing an offence and (especially if the car behind is a Police car) will probably be pulled. It won't be for having no mudflaps though, it will be for other offences.
I suppose that there might be issues if as a result of removing the mudflaps you cause an accident and your insurers find out that you have modified the vehicle by removing the mudflaps and this action has consequently caused the accident. In this case you would probably be uninsured as a result of a non-declared modification, although it is difficult to see how it could be proven that the removal of the mudflaps directly resulted in the accident.
Post #158873 31st Jul 2012 7:52am
T1G UP
why worry about anyone elses motor! do they give a Censored about you and yours.......
mud flaps are a pain.....an afterthought.
i have a plan to rectify the rear flaps issue.
Post #158874 31st Jul 2012 7:52am
I find it hard to believe that anyone would remove the mudflaps simply to improve the fuel consumption of a Defender, and I suspect that the OP (Shax) has removed the mudflaps for other reasons and has incidentally found an improvement in fuel performance. If you are that desperate for fuel mileage, don't drive a Defender!
I presently have no rear mudflaps on mine (one fell off and was lost in Dorset's great floods a few weeks ago, and it looks stupid with just one, so I took the other off to match) and to be honest I don't notice much difference in ejected crud. It seems to throw up no more without them than it did with them. The benefits are that they now can't rip holes in the bodywork when you reverse over them, or when prolonged flapping work-hardens the panel the outer end is attached to.
Post #158875 31st Jul 2012 7:59am
Re: Puma "Airbrakes"....
That sounds like about 10%, which seems like an unfeasibly large increase just for removing the mud flaps Confused I suspect other factors at play. Darren
Post #158876 31st Jul 2012 8:04am
Shax
I removed them to derust and respray the brackets, and never got round to refitting the airbrakes as I think it looks better without them.
Re people whinging about chucking up excessive amounts of spray, if people were to leave a bigger gap in the rain, then it wouldn't be an issue.. And with regard to dropping mud on the highway, how will mudflaps that are already caked in several inches of mud reduce what the tyres chuck out?
Just for info, I used to get a regular 28.5MPG, filled up this morning, and it works out at 30.4... ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #158882 31st Jul 2012 8:52am
It will be interesting to see if this improvement is sustained, a single fill is not a long enough test to be conclusive since other factors may well be at play. It is however food for throught.
Although I do record fuel purchased and the mileage at each fill I haven't yet calculated MPG for the period after the flaps came off, but it will be interesting to do so in the light of your observation.
Shax, is yours a 90 or 110?
Post #158884 31st Jul 2012 9:05am
I'm considering an LS1 lump and auto in mine, Censored economy, I cycle work 99% of the time Mr. Green
Post #158885 31st Jul 2012 9:08am
dgardel
Italy
106 MPG changing the external shape of my Defender.....
Now I have a little more room also..................
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #158887 31st Jul 2012 9:47am
Shax
It's a 90XS. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #158890 31st Jul 2012 10:07am
Page 1 of 3 123>
