Home > Puma (Tdci) > Problem with defending td4.
Morea
Well I have a problem with my defense. I tell you and I hope that I understand well what I ask. I have my defense rescheduled and canceled the EGR. Air Filter ITG. Mantec snorkel. I have tires 35 "x12.5xR15 et -32, +8 cm docks.
Problem, here I hope espresarme well. The problem comes when I go on highways with high slopes uphill. When I go to 100km / h in 5 sixth speed change as the car is stalled and costs go up and check smoky black (hot on any work running strong black smokes). As if he had no strength. I keep going up and the car stops, but the engine does not, the needle shaft rises above tenperatura. I begin to downshift the car horn returns to normal and the needle returns to its normal position. Below is heated cubibox lot, till the point that if you play the hand you burn. Before I turned on the engine fault light, but came back to reschedule and this happens. They clean all the injection system, filters, etc.. It reprogramming thing wrong? question will be put shorter groups for tires? or be otherwise? driving me insane and I find the solution faster. Thanks in advance. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158082 26th Jul 2012 3:11pm
T1G UP
Morea, im in Spain...near Malaga at the Moment.
its been about 35 degrees here so hot enough!
who did the map? do you have any diagnostic kit available? Can you put the defender back to a stanard tune?
Has this only just started?
Post #158084 26th Jul 2012 3:20pm
Morea
bufff, I am in Asturias, on the other side of Spain. Before I was rescheduled only, without invalidating the EGR and I did the same. Then we cancel and followed the same. This past week we came back with another reprogramming different and still the same.
The reprogramming I made ​​an acquaintance here dedicated to it, is autonomous. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158085 26th Jul 2012 3:29pm
T1G UP
You need to get it on a diagnostic machine. Could be maf, turbo, headgasket etc. tyres are big!
Post #158088 26th Jul 2012 4:10pm
Morea
I'm on it. But what I find strange is that only do so on uphill. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158096 26th Jul 2012 4:52pm
Morea
Post #158098 26th Jul 2012 4:53pm
T1G UP
Post #158099 26th Jul 2012 4:57pm
T1G UP
found another mentioning loss of power when hot http://www.defender2.net/forum/topic12520.html?highlight=decat
seems intercooler needs changing
Post #158111 26th Jul 2012 5:42pm
Morea
if so it seems. it's no problem of reprogramming, if not the shortness of breath or so I understand. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158113 26th Jul 2012 5:46pm
Eduardo
Morea,
It is a sort of "common" problem in high temps and forcing the engine (mine have the same issue) Some South Africans forum members have the same problem.
Main problem appear to be the coolant temperatura that reach a safety point and the engine goes to a "safety" mode. Mine has not been remaped and all the softwares upgrades has been done.
Some points that with a big intercooler the problem dissapears. In our case is winter now, so I will take cera of it in 5-6 months more.
Cheers Eduardo
Post #158125 26th Jul 2012 7:15pm
Morea
Thanks Eduardo, I was reading the other links and it seems if that is the subject. Since he was gonna set fire to the def Very Happy Very Happy Very Happy Very Happy Very Happy http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158129 26th Jul 2012 7:35pm
Morea
This is what happens to me. Sorry about the comments are in Spanish and is very difficult to conduct and record at a time. It looks at minute 5.53. It is very mild, just as it passes the slope and the terrain is flat. If the slope is longer def takes much more in reacionar vaja speed and max 40 or 50km / h, till they recovered. On Thursday it enchufare to a friend's computer and try.
&feature=youtu.be http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #158946 31st Jul 2012 3:46pm
MK
You need to downshift when going uphill. It is a diesel engine. Loories do as such.
Cambia a una marcha menor de tal forma que el motor funcione mas rapido al igual que el ventilador y bomba de agua. Puma 110" SW
Post #158951 31st Jul 2012 4:29pm
Morea
Well, yesterday if clean diesel circuit and radiator cooling included, more than anything to discard anything that is not uncommon for there.
Well, first contact cast Very Happy
Gives no machine failure or breakdown
The turbo blows at 1.2bar
When I pulled down the turbo stops blowing and placed above the atmospheric pressure
I did this in 5 th and 6 th up the port
Was detected also gives us 5.12 to 5.5V consumer when it should make no more than 5 as it is their feeding. http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #159521 2nd Aug 2012 8:36pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I run 35s with no problems at all 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #159537 2nd Aug 2012 9:11pm
