Home > Maintenance & Modifications > hand brake adjustment |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Hi all.
About 3 weeks back my hand brake warning lights started staying on because the lever was not seating properly. I took it apart and found the inner cable was pushing the lever up. I adjusted the drum as per the wners book and also adjusted the outer cable so the lever sat down. Now it is doing it again, is there another issue of which I'm getting these symptoms that I need to find or is more adjustment needed? Cheers. 300tdi 90. Rhubarb and custard let fly with their secret weapon. |
24th Jul 2012 4:48am |
Thought of that so took it off, still no better. Rhubarb and custard let fly with their secret weapon.
24th Jul 2012 10:38am |
