Home > Puma (Tdci) > egr valve.smoky puma
chopperpk
England 2013 Defender 90 Puma 2.2 HT Tamar Blue
hi there do u think my egr valve needs clean or brocken.i have a flat spot just before the turbo kicks in.and a lood off sootty black smoke.it has had a repap Crying or Very sad Crying or Very sad cycle
Post #157323 22nd Jul 2012 6:30pm
K9F
Are the symptoms recent or have they occured since you had your 'repap?' Wouldn't harm either way removing your EGR valve and cleaning it with brake cleaner if you've the time and inclination. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157328 22nd Jul 2012 6:50pm
chopperpk
hi there after remap.is it hard to take it of cycle
Post #157329 22nd Jul 2012 6:56pm
K9F
Trying to determine if it has been 'caused by the remap' itself. It really depends if you are 'mechanically minded' and have the manual dexterity to remove it.
I was experiencing something very similar to yourself a long time ago and it was my intention of cleaning it, however never really got round to it. In the end as I was still under warranty and my MIL light was permanently on I had it swapped out at the dealers. If you do remove it yourself it shouldn't take more that 30-40 minutes at most if you're able as mentioned.
See here:
http://www.defender2.net/forum/topic2227.h...r+cleaning If you go through life with your head in the sand....all people will see is an ar5e!!
Post #157332 22nd Jul 2012 7:09pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Who remapped it ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157350 22nd Jul 2012 7:53pm
chopperpk
it was orlready remaped when i got it.so dont no cycle
Post #157361 22nd Jul 2012 8:26pm
Lorryman100
If you can hear the EGR cleaning cycle on shut down unplug the EGR and see if the symptoms remain. Lots of black soot smoke is a sign of over fuelling so check that the EGR is not to blame first. If you can revert back to the old OEM fuel file do that as well to see if the remap is at fault. Next on the list of over fuelling faults would be to replace the MAF sensor. These are not expensive at about £35 from a main dealer or online.
MAF sensor location, held in by two screws
MAF
EGR plug location
When it is unplugged you will get the MIL and 2 DTC's will be logged in the EMS, P1402 and P1409. If you have no diagnostic tool to reset the dtc's and MIL? Once it is plugged back in the MIL will go off after 40 ignition cycles without failing the self test but the dtc's will remain logged in the EMS..
Brian.
Post #157739 24th Jul 2012 4:30pm
