Home > Td5 > auto td5
Page 2 of 2 <12
bell-auto-services
The TD5 Compushift setup has had an update very recently to make it drive even better than it did already on the TD5's Smile It now utlises the boost pressure sensor inputs as part of the gear change shift map permissions.
Pete
Post #157046 20th Jul 2012 6:37pm
ashtrans
Site Sponsor
As Pete says, previously we have taken the throttle position signal (TPS) for both the shift speed and shift pressure maps but this has it's limitations and can give hard downshifts when you come onto the throttle when on overrun, we now have software on the later CSII compushift ECU that allows us to use the manifold air pressure (MAP) signal to control the shift pressure map, this means smoother downshifts when it shifts with low boost, it's an easy software upgrade if anyone wants to try it, Dave Dave
Post #157208 21st Jul 2012 5:22pm
JeremyJ
Will phone you Monday about doing it on mine
Post #157209 21st Jul 2012 5:30pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
can't wait. hopefully arranging a test drive with Dave in his Puma later in August......i'll be in touch after my holiday.
regards BM52
Post #157210 21st Jul 2012 5:49pm
jst
Dave - has Philon had that update on his? you know he likes a gentle drive! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #157219 21st Jul 2012 6:52pm
T1G UP
Pete
trouble is pete therem only 4 speed. no good for economy or coolness Whistle 8 speeds now you know
Post #157224 21st Jul 2012 7:11pm
ashtrans
Site Sponsor
Not yet, he dropped by last week and I remapped the compushift for him and he is dropping it back after king of valleys for this and for us to fit a new type of potentiometer XY switch which should be more waterproof than the genuine switch Dave
Post #157233 21st Jul 2012 8:27pm
jst
improved XY switch sounds good, had a few issues in Croatia with the current one. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #157437 23rd Jul 2012 12:48pm
Page 2 of 2 <12
