![]() | Home > Td5 > Alarm and central locking problem |
Anyone
Was it that way from the start or suddenly?
I believe the dealer can switch it on and off. I know he can switch the immobiliser off. Or you can do it yourselves with a faultmate or something like that. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
We only just got the landy and the fault was allready there and stupidly i thought it would be an easy fix
It could be an easy fix if nothing is wrong. But then why did they switch it off? Roel
Ok i'm an idiot i went through everything again today and found a fuse i missed so it now works (apart from the drivers door which i think is the solonoid) so thanks for the advice
Ray |
That's even better. Roel
Yes it's great but i do still have a wiper problem where there is no intermitent and they won't park in the right place and for some reason the horn only works off the rear window wash button
![]() Cheers Ray |
Have a look here:
http://green-oval.com/joomla/index.php?opt...;Itemid=29 What you want is de CD-2 defender. It is very usefull. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
