![]() | Home > Puma (Tdci) > Puma Keys |
Niel Member Since: 14 Sep 2009 Location: Sandton Posts: 27 ![]() ![]() ![]() |
I noticed that some of the newer Defenders have "modern" ignition keys, mine still has the traditional Defender key.
Does anyone know why it changed ? Puma 110 sw White No extras yet. |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
I had to get a key spare key cut for ours and the key was under British Leyland. On that basis I would say I have the old style key!
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
They changed so people didn't think you'd turned up in Austin Allegro
![]() 1968 1/32 scale Britains 109 Pick up. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6158 ![]() ![]() ![]() |
I bought a new key set for my project110, with ignition barrel, and i got the "new" key as well.
It certainly feels nice, however when the headlights are turned on (this is Td5, so with the column mounted light switch) and you try to start the engine, your hand (well,. my shovels anyway) get in the way of the light switch, the space is quite confined. hardly an issue i know! ![]() |
Yea, land rover owners always lost out at certain throw your key in events cos the decent birds thought you'd turned up in a all agro Original Member Pie n Pea Club. 110 HCPU Tipper |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 ![]() ![]() ![]() |
The alarm fob is still the same Lucas unit as used on the 300tdi and probably earlier.
The key isteslf, they have just redesigned the plastic bit on the end, making it larger with the landrover logo moulded into it. I'm suret he metal key blank is the same. As far as the Puma having a very sophisticated anti theft system, it is a shame the alarm can be defeated in seconds (see LR stripped post) It does however show that the immobiliser works very well. |
