Home > Maintenance & Modifications > After market DRLs
Tazz
After market DRLs
I've seen the various kits available for after market Daylight Running lights but have a question for which I can't find an answer.
As I understand the law, DRLs can be up to 21watts, must only be activated when the ignition is on,and must be extinguished the normal lighting is being used. The first two bits are easily achievable through using an ignition feed. However, the only way I see to comply with the third requirement is a manual off switch. I would have thought that there would a relay available which automatically cuts power to the DRLs when power is fed to the front lights?
Does anyone know if such a really is available, or do people with after market DRLs rely upon remembering to switch them off when the normal lights are required?
Post #155691 15th Jul 2012 9:32am
ZeDefender
The Hella ones I have do it automatically. There are two wires (fed through the bulkhead) - one to the cigarette lighter fuse for "ignition turn on" and the other to the sidelight fuse for "lights turn off". They were a bit more expensive than simple LED units but simple to wire up and great quality Thumbs Up
Matt Tell someone you love them today because life is short.
Post #155692 15th Jul 2012 9:42am
T1G UP
speak to Tim at mobilecentre.
the kit they sell uses the front side lights as drls so no need for them to go out when main lights are used.
got a kit on order myself.
Take a look at Kens picture gallery, i believe he has them
Post #155693 15th Jul 2012 9:43am
ZeDefender
Aren't the standard Defender sidelights rather weak or can you upgrade them e.g. with LEDs? Tell someone you love them today because life is short.
Post #155695 15th Jul 2012 10:02am
T1G UP
these are what im fiiting
Post #155699 15th Jul 2012 10:51am
ZeDefender
They are definitely not dim Thumbs Up Thumbs Up Thumbs Up
Do you know where they take the "ignition on" power from? I had to go through the bulkhead to the fuse-box as no-one here knew of a suitable source in the engine compartment. Tell someone you love them today because life is short.
Post #155704 15th Jul 2012 11:28am
T1G UP
TBH no. Porny, adafish or mobilecentre can answer that. im having mine on a switch though so i can kill the drls when off roading etc.
Post #155706 15th Jul 2012 11:47am
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have fitted the Mobile centre lights.
The live feed needs to come from the dash area, but could easilly have an over ride switch to turn them off.
Very easy to fit and wire in.
The DLRs are very bright, but their power halves when side lights or main beam comes on - so they comply to the law - similar to the back red lights when you put the brake on - ie the brightness doubles.
Excellent product and very good service from Tim.
Post #155708 15th Jul 2012 12:05pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I've the mobilecentre ones and despite some great wiring diagrams from k9f (thx Mal) and hunting round the engine bay I ended up taking the lead off the radio ignition on.
Stu
Post #155709 15th Jul 2012 12:09pm
ZeDefender
Cheers Thumbs Up
Looks like I'll leave mine alone then (was considering rewiring to tidy up the fuse-box). Pity...
Post #155720 15th Jul 2012 1:52pm
Merlin
I changed my front side lights to NAS type reversing lights with a 21/5 watt inside. These were supplied by Bolt on Bits, also the rear connector so you can wire in the standard side lights and the new 21 watt ones.
Then I stuck a relay in, connected to the reversing one (that gives power on indication) and ran a wire to the front into another relay that is operated by the side lights.
So the DRLs come on with the ignition and are turned off by the side lights.
Merlin
Post #155728 15th Jul 2012 2:42pm
ZeDefender
Confused I'm thick - I admit it Laughing
I didn't get the bit "connected to the reversing one (that gives power on indication)" - is there a live feed at the back that comes on with the ignition? That would be very interesting for other projects... Tell someone you love them today because life is short.
Post #155740 15th Jul 2012 3:37pm
Merlin
The reversing relay, situated under the passenger’s seat (if the Land Rover fitting guide has been followed) provides a live (12+) feed to the white socket (called the 12S) by the tow bar (on terminal 6). This is sometimes referred to as the S relay.
That’s where I took the 12v from, as it’s only there when the ignition is on.
Merlin
Post #155742 15th Jul 2012 3:57pm
the alternator goes live when the engine is running Thumbs Up
Post #155744 15th Jul 2012 4:07pm
ZeDefender
Cheers Thumbs Up
Thanks. I wondered about that too but a work colleague warned me against possible "voltage spikes" - could be b*llocks but sounded feasible at the time (I also wanted the lights on without the engine running...) Tell someone you love them today because life is short.
Post #155748 15th Jul 2012 4:17pm
