Home > Puma (Tdci) > Power steering recommended fluid for Puma
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi all,
Any idea the recommended Power steering fluid for the Puma?
Slight leak (drop) requiring top up in my 90 Puma 2007.
Grateful for suggestions
Joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #22014 13th Jan 2010 5:32pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
DEFENDER – 2007 MY onwards TD4 2.4L Diesel
Texaco Cold Climate Fluid 33270 1.6 liters / 3.4 US pints
Part numbers:
STC50519 – 1 liter container
STC50517 – 2.5 liter container
or LR002261 One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #22036 13th Jan 2010 10:08pm
jlerra
Cheers, thanks very much for the info on the Power Steering fluid.
regards
Joe
'El pepe flamenco' JLS
'El Pepe Flamenco'
Post #22051 13th Jan 2010 11:07pm
mse
Not that you will likely have Halfrauds by you.
But a Censored to find in any motor factors when you need it...especially in Inverness, on a Sunday Mike
Post #22053 13th Jan 2010 11:10pm
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
For hotter climate?
Hi, we live closer to the equator so there is average 30 C temperature all the time. I could not find this Landy manual recommended power steering oil type ''Cold Climate Fluid 33270'' in my country. Anybody got any suggestions for alternate model or product for power steering oil. Appriciate. Cheers!!! Very Happy Very Happy
Post #155541 14th Jul 2012 3:19pm
spudfan
Ireland
Have a look at the pipe work from the power steering reservoir from underneath the vehicle. Some vehicles, including my 2008 Puma had leaks owing to under tightened joints in pipe work.Very easily tightened and stopped my loss of powersteering fluid.
Never found any one who stocked the Texaco Cold Climate stuff other than a dealer. You can get long life 5 year stuff which should see you O.K. for the occasional top up.If it is a major drop in fluid level or constant small top ups you probably have a leak, so check the pipe work from the reservoir. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #155558 14th Jul 2012 4:39pm
dilukabey
Many thanks spudfan.
I found leaks from the power steering oil resevoir lid in my previous 300tdi CSW but i think it was when over filled. I guess same thing happened to puma also but im sure it was not over filled. Now the fluid level indicator lid is at barely touching the bottom edge so should refill mine. Cant see any other leak. Dont know may be its landy.
Has anyone used any other brand or type PS oil other than the book?
Cheers! Very Happy Very Happy Very Happy
Post #155672 15th Jul 2012 6:19am
jlerra
Steering box fluid
Hi,
After a small leak from the steering box for while and tightening all connections , I eventually had to replace the steering box as it leaked from the seals.
El Pepe Flamenco JLS
'El Pepe Flamenco'
Post #155697 15th Jul 2012 11:27am
spudfan
Ireland
I had the steering box replaced under warranty on the 2008 Puma. Found a little dampness on it, nothing major but as it was under warranty I got it changed. Any motor factors will sell you an additive like radiator sealant, but for your power steering system which might be a short term solution for you.
Regarding other brands. If you get a decent specification fluid, just see how long it is before you are recommended to change it-it will be on the label. It might not have the life expectancy of the Land Rover recommended fluid but once you keep within the stated time frame for changes on the label you will be O.K.
I always view these things things as if I were in the back of beyond. You will not always be able to get the stuff recommended by Land Rover, but if you buy decent stuff and change it more frequently you will be alright. 1982 88" 2.25 diesel
Post #155761 15th Jul 2012 6:00pm
