Home > Td5 > Sump removal
Geoff 90
Sump removal
Just wondering is there much work to remove the sump on a td5 90. Just curious as if it's not too much work was thinking of taking it off to clean up some of the oil sludge that I'm sure has built up over the years.
Geoff
Post #154714 10th Jul 2012 11:17am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
This is a Discovery but I imagine the process is identical. Check the oil pump sprocket while your at it.
http://www.discovery2.co.uk/Oil_pump_bolt.html
Post #154720 10th Jul 2012 12:11pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
It its a straight forward process to unbolt but its a bit tricky to manouver out without jacking tha front of the vehicle up for clearance.
Make sure you thoroughly threadlock and torque the bolts back up afterwards, otherwise they have a tendancy to fall out - don't ask how I know. 2002 Defender 110 DC
Post #154810 10th Jul 2012 6:48pm
