Home > Maintenance & Modifications > awning idea for those without roofrack + LED floods
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
budget idea
you only need to have a rooftop tent .. Laughing
Alu profile as used on caravans, 2x 120cm
Caravan awning 2,5 x 2m
Extendable poles and some tensions lines
16 screws
dont remember cost exactly but surely under 100eur total.
et voila
profile
storm yesterday survived without problems
No need to remove when packing the tent, a bit of clever folding and it hides inside the RTT cover, poles fit inside the tent under mattress.
Happy Camper again
Very Happy
PS 1 big benefit this has compared to a classic RR mounted awning is the fact that you cover the complete corner and include the cover of the overhanging RTT
Post #153956 6th Jul 2012 3:54pm
tatra805
Realize its not a hot topic, Laughing anyway
LED floods on a budget
Addition to the awning i wanted to have some floodlights.
Experimented with H3 Led bulbs in worklights but these have almost no output and dissapointed big way.
These 10W 220VAC LED floods were advertised as having an internal 12VDC connection. Even a confirming call with the seller only resulted in recieving them and finding out the leds are driven at 30VDC and wont work on 12VDC, even with the correct resistor inline etc.
At 26 euro not a big a loss, but.... maybe....
Have put one on my small 150W inverter and they work.
The inverter takes 0,3A without load. With one light on i measured 1,2A, eventually dropping around 1,1 once the led was on temperature. Thats still a heap less than a 55W Halogen, and a claimed 75W equivalent output.
Put one on the underside of the RTT (wont advise on alu platform RTT's but the easy awns have a wood base)
Very happy with the light output, its not too much to be blinding but enough to read a book, and the 120° angle really spreads the light nicely.
Should probably warn about the risks of running 220VAC in this case but if you respect IP ratings and wire them up accordingly i am confident the risk is minimal. And in pouring rain its still an option not to switch them on after all.
2 weeks before the holidays, will finish the wiring this week and even think about using a dedicated low power inverter for these lights only, at +- 40 euro not really an issue these days.
Post #154425 8th Jul 2012 9:02pm
