Home > Puma (Tdci) > Door hinge bolts |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4658 |
Just noticed one of the bolts from the top door hinge is missing. It is one from the hinge plate over the quarterlight window. The remaining one was loose so I tightened that. Are the retaining nuts inside fixed to the body or just tightened in place by the bolt pulling them? Anyway check yours. Have e-mailed the dealer. 1982 88" 2.25 diesel
13th Sep 2009 10:58am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
13th Sep 2009 12:43pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Your right about the nylocs Derek, but haven't noticed the use of Loctite though 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
13th Sep 2009 12:48pm |
Should have said that it is the rear door. It is the bolt closest to the door above the quarterlight window. As the vehicle is under warranty I will get the dealer to do it. I do not want to break any trim clips and have rattling trim in the back. If the nut that receives the bolt was fixed to the vehicle I could just screw in the replacement bolt and not have to remove trim to do it. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
13th Sep 2009 2:29pm |
14th Sep 2009 4:17am |
Or was it that the car nearly fell from under the bonnet that was quite early into your trip wasn't it. 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
15th Sep 2009 7:27am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
I have a similar issue to this. I need to replace the bolts in my rear door hinges as they are all rusting quite nicely, but am unsure as to whether I will need to remove the interior trim panel around the o/s rear quaterlight? Does anyone know if the bolts that fix the rear door hinges to the body are captive? The bottom hinge bolts through into the inside of the wheelarch box, and I can't see how you would get at the back of it if they're not captive.
If I do have to remove the interior trim to either side of the back door, what are the trim clip fixings? They have a little grey cap on them, but are metal underneath and look a bit like small rivets. I have a trim removal tool, but don't know if they just 'pop' out? Any help greatly appreciated! Cheers. |
27th Mar 2011 2:11pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Go into the back of the car and one quick tug inwards and the trim will be off...its not too hard on those parts. Mike |
27th Mar 2011 4:31pm |
I've just replaced all my bolts and can confirm
front doors into mirror are captive front doors lower into bulkhead are captive front doors are loose but if you are carefull you don't have to remove the door panel 2nd row doors .. into car are accessable from inside car 2nd row doors into doors - again if you are carefull you don't have to remove the door panels backdoor ... trim is easy to remoe HTH |
27th Mar 2011 6:08pm |
Thanks for the advice mse and bpman. bpman - presumably you had to remove the small trim panels around the rear quaterlights at the side of the rear door to get at the hinge bolts?
27th Mar 2011 6:21pm |
yes, these are pretty easy to remove, first pull off the window surrounds, lift the carpet (if you have some) and there are 3 plastic clips, carefully unscrew and you can then pull the plug out, if you break the plug/clip, you can get them at you dealer or halfords sell them too. the lower hinge on the rear door ... you need to climb under the truck, remove the plastic cover panel and the rest is easy.. |
27th Mar 2011 6:54pm |
