Home > Puma (Tdci) > Gearbox problem at 12k miles |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
just out of interest did you park it in neutral or in gear?
the reason i ask is that i find the transmission tunnel area gets very warm on a long journey and i just wonder if heat expanded metal is a factor in a lot of these problems? |
5th Jul 2012 3:49pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17248 |
If your gearbox seems to get excessively hot, it might be worth checking that it is not overfilled with oil. There have been several very interesting recent posts on this subject, and it seems that a lot of Pumas have left the factory or dealer with far too much oil in the box. For reasons which are not clear (at least not to me) this seems to cause excessive heat build-up in the box.
5th Jul 2012 4:57pm |
marklockett2103 Member Since: 08 Feb 2011 Location: West Sussex Posts: 32 |
We did 400 mile trip on last Thursday, all was fine. towed my jetski approx 20 miles on sunday, parked in the drive, washed the car, then moved it up the drive about 2 hrs later, all appeared ok. came to move it Monday eve, and was stuck in gear... very odd.
since spoken to the dealer who mumbled something about plastic parts in the seletcor mechanism and it was 5 hrs to fix. still they are replacing all the mudflaps again, 4th time lucky??? |
6th Jul 2012 8:47am |
Always leave it parked in 1st gear, our driveway is on a hill, never been over trusting of the handbrake, i have heard of them rolling away as the transmission brake drum cools down...
6th Jul 2012 8:49am |
cheers Blackwolf, i'll get that checked.
6th Jul 2012 9:58am |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 |
Interesting. Recently I experienced, when I parked my puma 110 high cap on a fairly sloped surface with hand break on + gear at 1st position, went away and suddenly noticed the vehicle was moving reverse in a sequence. I was terrified and got back to vehicle quickly to stop it. Has any body experienced simillar story?
7th Jul 2012 12:36pm |
