Home > Puma (Tdci) > So, 2.2 Puma in South Africa has no DPF? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Puma 2.2 for South African/African market does not have the DPF due to the wide unavailability of low-sulphur diesel. If what you are referring to is just below the turbo, I think it is the catalytic converter -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jul 2012 9:19am |
Fatpig Member Since: 31 Oct 2011 Location: Chengdu Posts: 22 |
Naks,
thanks for the reply, what i found ccording to the workshop maunal is the DPF it is quite big located next to the engine on the right hand side, but my question is does the SA version not the DPF altogether, or does it still have the empty DPF can installed? |
4th Jul 2012 3:06pm |
Err, that I do not know, and mine's not a 2.2 so I cannot check, sorry! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th Jul 2012 3:09pm |
