Home > Td5 > Defender TD5 Alarm not working
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi my alarm has never worked since owning the vehicle, took it to have set up, both key fobs were checked and worked when synchronised to the car with a horn bleep and indicators flashed once but the alarm will not activate. The technician said, he as checked all settings but could not understand why the alarm isn’t working, does anyone have any ideas for me to pass on to the technician to try out please.
Mark
Post #153078 1st Jul 2012 5:27pm
JWL
Is it actually activated? It's my understanding that you can isolate the alarm with the likes of the plug-ins such as nanocom.
Post #153101 1st Jul 2012 7:07pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Defender TD5 Alarm not working
+1 it has probably been deactivated with a nanocom or similar, you will have to activate it the same way again Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #153189 2nd Jul 2012 1:18am
Porny
Site Sponsor
I can have a look for you if needed...
Only based 2 mins from Junc 9 M42.
Ian
Post #153200 2nd Jul 2012 6:52am
tazmarkuk
hi guys, thanks for the info, does this mean it can only be re-activated with a Nanocom? the technician was using a Land rover TEST BOOK i believe, so thought this would do the job
Mark
Post #153449 3rd Jul 2012 4:50pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Yes. I've enabled mine which was shipped without the alarm option n I've added in by soldering the cdl relay to lock the doors. There are many options and setting in the 10as which can stop a td5 from starting and baffle those at the dealership.
So in short, a nanocom is what you need. This is the affordable option, the test book is not something the common mankind has access to. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #158214 27th Jul 2012 2:32am
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Just a thought.... could the previous owner had an issue with one of the door or bonnet switches that would cause the alarm to think offending door or bonnet wasn't shut???
As a lazy/cheap work around, they just disabled the 'mis-alarm' setting on the 10AS instead of fixing the problem.....???
@tazmarkuk ..... I'm in Buckingham area and have a working alarm and Td5 Nanocom. I'm by no means an expert but if you are in the area, we could always hook the nanocom up to both trucks and compare my 10AS settings to yours... Could be a good place to start.... Although I'd take Ian (Porny) up on his kind offer as he's a heck of a lot nearer to you and will have forgotten far more than I know Bow down Jon - 110 td5 [sold]. Currently Defenderless.
Post #158280 27th Jul 2012 10:35am
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
When I bought my 04 Td5 110 the previous owner had the Alarm & Immobiliser deactivated, his thinking was that if he had a key fob issue he would be able to get in & start it with the key. The central locking would work with the fob, but not the alarm.
I went along with that reasoning but when I bought a nanocom I was easily able to reactivate the Alarm & immobiliser.
Re Party Monkeys thoughts, I haven't tried but looking at the Nanocom Evo menus I think you can turn off individual alarm inputs (door switches)
Post #158309 27th Jul 2012 1:20pm
achuakh
Door switches have only 2 inputs.
Driver door and all other doors, regardless of the number of doors on your truck.
You can however disable the alarm but use the cdl.
You can even enable auto relock if you accidentally unlocked n didn't open the doors after 1minute!
Really a whole lot of options for the 10as. So make the most of it! From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #160449 7th Aug 2012 7:52am
