![]() | Home > Puma (Tdci) > Headlights failed |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Have a look here
http://www.defender2.net/forum/post152250.html#152250 The light switch is a common failure |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 ![]() ![]() |
Thanks I see this prob has already been discussed. Sorry for repeat question
No problem - you will see that there are some links in the thread to give you some pointers
opened the switch some melting evident-but it was still making contact Checked fuses in the CJB , all fine , swopped them out to make sure. Swopped the little black relay on the far right side under the coloured ones.
Still no lights when the switch is pressed to position 3 . Am I missing something--is there any fuses in the BJB that controls the lighting circuit? |
